Singer 1120 Mechanical Sewing Machine Logo
A
Anonymous Posted on Sep 02, 2014
<!-- from fixya rte -->How do I replace spool pin - Singer 1120 Mechanical Sewing Machine
Steve Fuhrman
Level 1:
New Friend:
  • Contributor 41 Answers
  • Posted on Sep 02, 2014
Steve Fuhrman
Contributor
Level 1:
New Friend:
Answers
41
Questions
Helped
8038
Points
83
Some spool pins are screwed in and some are just wedged in. You can purchase a wedge in spool pin from your local store and use it to replace a screw in one but you cannot use a screw in pin to replace a wedge in type.
1 Related Answer
sylviaivie
  • 1564 Answers
  • Posted on Sep 03, 2012
SOURCE: how to replace spool pin on model 5160 singer sewing machine
Drill and tap out the broken bit. Put new one in.
2helpful
2answers
Model SE-400. How can I replace the spool pin?
IF IT WAS PLASTIC /NYLON I HAVE USED A LEFT HAND DRILL BIT AND CAREFULLY DRILL IT OUT USUALLY IT WILL UNSCREW WHILE DOING IT THEN JUST SCREW THE NEW ONE IN WWW.HARBORFREIGHT.COM SELLS THE DRILLBITS
How to remove broken horizontal spool pin of Singer Sewing machine model 6550 and replace with new spool pin?
It appears to be just "hooked" on according to the photo, and you can get the replacement part for $4.00 using this link: http://www.sewingpartsonline.com/spool-pin-singer-3709-sewing-machine.aspx.
However, before you go to all that trouble, you can also just use the auxiliary spool pin used for twin needle sewing which came with your machine but can be purchased from the same site for about the same price.
I don't use either -- I just put the spool in a cup behind the machine and thread from there. See? One way or another, you're back in business!
1helpful
Hello i have just obtained a Hasqvarna 3600 and the cotton spool pin has been pusged too far down and i can't get it out. Does anyone know how to pull it out? Please
If it has not been pushed all the way down so part of it is still projecting above the machine, you can cut a piece of plastic drinking straw and place it over the spool pin. This works very well for those extra large spools that are too tall for the spool pin. In some instances, some people simply place the thread spool in a cup or jar on the table to the right and behind the machine. Or, create a spool pin with a wooden dowel attached to a flat surface.
Otherwise, the pin may need to be replaced and repaired by a technician. But, you can get by without a spool pin on the machine.
1helpful
How to take back off bernia 1090
It doesn't sound quite right to have to remove the back cover to replace the spool pin. Most metal pins just pull out or push in, although there are some that the pin has a screw thread. But my older Berninas have a smooth metal pin. Just a thought...
1helpful
2answers
How do you replace horizontal spool pin
Hi Phyllis I believe this youtube video will help you, Take care...CHEERS..
https://www.youtube.com/watch?v=abGDVhDlZLs
1helpful
Do not know how to replace spool pin and spool cap
It looks like it might just snap into place. Of course that means you have to remove the broken bits which may require a drill, small bit and needle nose pliers.
1helpful
2answers
Spool Pin Broke off
Ask you local Singer dealer, be armed with the model number when you call.
Freestanding spool holders can be bought (or made.)
Broken plastic part within which thread spool pin is inserted
You can search for:
Make Model parts diagram
to see what replacement parts are available.
If not, you can probably devise something to improvise. I've used plastic drinking straws as spool pins, or plastic chop sticks.
Lost Spool pin and cap for QuikStitch SP-402
Welcome to FixYa. If you have a spool stand, that might work as long as you can thread the machine properly (give it a try!). When the thread is placed on the machine's spool pin, the spool cap keeps the thread in place and helps the thread unwind evenly - so if you are using a spool pin, you really do need a spool cap.
If the spool stand works, you are good to go. If you need to order replacement parts, I've provided a link the manufacturer's website. From there, you can contact customer support and find out if parts are available. If you can't order replacement parts, ask customer service if the machine is compatible with another brand. Another option would be to buy a spool pin and cap at a sewing machine dealer. Take the machine with you and and make sure the parts fit before you buy them.
Here's the link to the site I mentioned:
http://www.topinnovations.com/products/sew/SP-402/SP-402.html
Thanks for stopping by. If you have an extra minute, feel free to rate my solution. I'm eager to improve my solutions if they are not helpful. If you have further questions or would like to consult with another FixYa expert, just leave a comment and I'll do what I can to resolve your problem.
Top Singer Sewing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
