SOURCE: trouble with Karcher Pressure washer
Dear Pgarciax,
It is important that you must have mentioned the model number of your Karcher. Just the same I can surely say that your machine's fault lies in the "SPILL VALVE"
When the gun is open and pressure is being produced, the spill valve is in a relaxed position. Also it has at the bottom a valve, which when pressure is produced it is closed. If this does not close due to dirt or corrosion, the pessure goes down. Now when you close the gun,pressure forces the spill valve down to close the electrical system. Now if the "o" rings of the spill valve are damaged, the machine will start going on and off while in stand-by. So if you know how to locate the Spill Valve, all one has to do is change it with a new one.
In some Karcher machines there are 2 spill valves. One regulates pressure and the other one is for switching off the machine when the gun is closed.
Low pressure could also be due to faulty suction or delivery valves. Most probably the suction valves.
But when saying that there are short interruptions while in stand by, I stick to the fact that the spill valve needs renewing.
Regards,
MG.
SOURCE: karcher 2600 psi pressure washer wont stay running
Remove and clean the carburator. Sound line a stuck needle on the float.
SOURCE: my karcher pressure washer has lost its water power
I have the same problem. With mine I have to remove the tip that I am using then pull the trigger and then replace the tip and pull and pressure should return. I believe that one of my valves is sticking causing me to reprime the pump frequently. I am trying to clean or replace my valves to fix the problem.
I hope this helps.
SOURCE: Karcher pressure washer 411A. loss of pressure...
411a when i turn on it gos for 1 min then i have too press it on and off 3or 4 times befor it works and it only stays on for 1 min.
SOURCE: My 2200 Gc Karcher pressure washer oil got mixed
If you are talking about the oil in the pump then it should be 10W30 but must be NON DETERGENT. Remember the reservoir should only be 1/3 full
