Whirlpool GEW9250 Electric Dryer Logo
Posted on Nov 13, 2017
I have a Whirlpool Cabrio dryer w/Steam. It
I have a Whirlpool Cabrio dryer w/Steam. It appears to be acting erratically. The remaining time may tick down to 15 minutes and then jump to 44 minutes. It might overdry the clothes or might leave them wet. It would seem to me that there may be a problem with the sensor or the control board. Any help would be greatly appreciated.
5 Related Answers
Anonymous
  • 261 Answers
  • Posted on Sep 16, 2008
SOURCE: Dryer shuts off prematurely
The E1 code is a replace control panel code and a good way to check a sensor is to open the door with a empty machine and at the top of the opening there is a switch. Press it and start the dryer, watch the indicator for the sensor then get a wet finger and hold it across the two silver bars in the dryer, if it senses then maybe it is a mixed load or how is the machine leveled? I will lower the machine toward the sensor for better contact because after 3-5 passes the machine will assume the clothes are dry. If the sensor doesnt read then there is a question with the two mov varistors attached to a pig tail before the sensor. Here is a link to see what they look like.
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=529092&PPStack=1
Anonymous
  • 1902 Answers
  • Posted on Feb 11, 2009
SOURCE: Whirlpool electric dryer LEQ8611LG1 not drying on sensor dry.
Check your lint trap and the vent. make sure that there are no obstructions in either of them. Then take a look at your timer to since it is not stopping when you tell it too.
John Morganti
  • 864 Answers
  • Posted on May 29, 2009
SOURCE: NEW Electric Whirlpool Cabrio Steam Dryer; NO HEAT
Check temperature sensor.  Check to see if heating element is OK.
Anonymous
  • Posted on Oct 14, 2009
SOURCE: whirlpool cabrio steam electric dryer has sensor light on and does not work
have a problem with my cabrio dryer its powered on but when i push start the sense like comes on and does nother whats the problem
Anonymous
  • 1554 Answers
  • Posted on Mar 02, 2011
SOURCE: Whirlpool Cabrio model WED6200SW1 clothes dryer
There are two thermistors (thermal sensors) in this dryer; one is the outlet thermistor located on the blower housing and the other is the inlet thermistor located on the heating element housing as an integral part of the high-limit thermostat.
These thermistors are negative coefficient type and monitors the dryer temperature on their locations according to their resistance which varies inversely with the temperature. The resistance drops as the temperature rises and rises as temperature drops.
One or both of the thermistors has an open connection or high resistance which makes the electronic control board thinks that the dryer temperature is low no matter how high it is. The electronic control board then doesn't cycle the heater relay and continue to turn on the heating element. The dryer temperature continues to rise and this blows the thermal fuse.
Make sure the thermistors are connected snugly. Remember that loose or open connection means high (infinite) resistance which makes the electronic control thinks of low dryer temperature. Measure the resistance of each thermistor then refer to the tables below. Replace the thermistor if the resistance reading doesn't comply with the table.
Let us know if you need further advice. Please accept the solution should you find it helpful and informative. Accepting the solution will not stop you from communicating with the expert. You can still communicate with the expert should you need further advice regarding the issue stated herein.
On a cabrio whirlpool dryer what does E4 and F4 codes mean
A "F4E4" (Low or No Line Voltage) code indicates there may be a problem with your home power supply, keeping the dryer's heater from turning on. The dryer will continue to run when this diagnostic code is present. Touch any pad to clear the code from the display and return to the estimated time remaining.
Why is my Whirlpool cabrio platinum dryer leaking water, and taking over an hour to dry clothes?
Is this an older dryer? Long drying times are often caused by lack of good heating or poor air movement through the drum. Air movement depends on a properly turning fan and a clear exit of hot moist air to the outside vent. Check and see if you get a strong blast of air from your outside vent. If you don't, you may have a fan problem, plugged vent, or kinked vent tube. The water leaking could be because you don't have any drying going on due to the aforementioned problems.
My Whirlpool Cabrio dryer has water leaking in it. How do I fix this or what's causing it?
This model has steam support, so it should have a cold water connection to it. Check for leaks where the hose connects to the rear of the dryer. If you do not use the steam feature, you can shut off the water and that will probably end your problem.
How hot does a whirlpool cabrio dryer get
It can because it has a water line coming from washer line it causes steam for you dryer.
Appliance repair
SERVICE MANUAL for bravos/cabrio dryers
Note: this service manual will show you how to access components. use the tech sheet inside the dryer itself for diagnostics.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
1helpful
35helpful
2answers
Whirlpool cabrio steam electric dryer has sensor light on and does not work
Top Whirlpool Dryers Experts
Virgil Watts
Paul Bade
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
