Hi newish oven,seems when all the ovens are off the fan is blowing cold air, any ideas?
cold air from the fan forced element area in the oven? or from the air vent just above the door? if its from the air vent then this is normal if your oven senses the outside cabinet is getting to hot it will bring on the fan and if its still to hot after u turn it off the fan will continue as its circuit doesnt run through the control knobbs meaning it wont turn off with the oven its controlled via a overload thermostat so the fan will remain on til it gets within its acceptable temp range and the thermostat will cut power to the fan, if it remains on for hours and hours or even days you will be looking at a new thermostat (cheap as dirt like only a few bucks) or worst case a controller
