20 Most Recent
KitchenAid Architect Series KEMC308KSS Electric Double Oven Questions & Answers
Kitchenaid kehc309jss05
yes this is the resullt of inter change wiring connection,wierd outcome function..the only best thing to do is to find a shematic diagram of this unit .or search in the internet...
Kitchenaid Architect Electric range model
Hi
Thanks for using FixYa. Error F2-E0 on your kitchen aid means that the keypad is shorted and to resolve this issue you’ll have to replace the electronic range control/clock (ERC). Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Can't change light bulb
yes you wilkl need to remov ethe micro from the oven mountingin order to access the light bulb (dumb-design) but no way around it
Kitchen Aid microwave door -- outer glass
Lisa, I do not have a solution, but have the same problem. My KA superba micro has been used about 10 times. While it was off, and while no one was home, the outer glass in the door shattered. I suspect this may be a defect.
F5E1 or FSE1 error code DOOR LOCKED LATCH NOT OPERATING
On this double oven, each door has it's own latch
mechanism that consists of a motor, a position switch, and the door
switch used to activate the cavity lights. Because the error indicated a
latch failure (and the bottom door was locked), Start by cycling
the power to the unit. Each time the power is removed and then applied
to these ovens, both latches will lock then unlock the doors to ensure
they are in the home open position. By doing so, you might be able to get the
bottom oven door opened allowing me access to the latch assembly. With
the latch removed, I try to begin a clean cycle so you could watch the
motor operate and you will probably find that it will start to turn, but never would rotate
enough to lock the door. Since the position switch was not actuated at
the end of the motor operation, the F5 E1 error was again displayed. Replace the motor assembly E
I have a two ear old Kitchenaid gas range
You will need a new igniter module. The igniter module is told to spark by the control panel. There is also a flame detection for electronic start and that could be bad too.
The top display says F2:E1 and the oven won't
This is not exactly a solution, but it does explain what F2:E1 means. According to this page, it is a control panel malfunction. It may be caused by a shorted wire, but it may just be the control panel malfunctioning on its own.
Cleaning Inside Glass Oven Door of KitchenAid KEMC308KSSO
To dismantle the kitchenaid pro line oven door: there is a lever over the hinges that attach a door to the oven. The lever is right on top of the hinge. Pull the lever up. When that lever is in the up position, you can pull the door out.
