Error generated after replacing toner
TCR output abnormality. What is the status of your consumables (drum and developer)? You might need to replace the developer. Also, you should check if the toner bottle is turning; you should see it turning while the front cover door is open and the machine operates; if it is not turning, it is possible that the toner bottle was inserted wrong (by force).
Konica Minolta Error Codes & Solutions - http://www.kmcodes.com
Drum, Transfer Belt and Fusing Unit Firmware Reset - http://www.bizhubreset.com
Drum and Toner Chip Reset - http://www.chipreset.eu
Transfer Belt and Fusing Unit Reset Kit - http://www.resetkit.eu
SOURCE: How to setup scan to pc on Konica minolta bizhub 350 Error ED09C7
Your configuration sharing SMB folder is incorrect. Create desktop folder rename all upper case SMB right click on the folder and click sharing and set full control to everyone. Go to web brouser type in the ip address of the printer log on to administrator password 8 zeros or 12345678 and change the setting.
SOURCE: Bizhub Konica Minolta - Error Code C1183
First check the alignment front and rear of the finisher, check the finisher exit guide rollers if the paper is exiting properly, open both rear and the front cover and check the lower gears attach is the up/down drive belt. that lower gear one might be broken by the pin slot.
SOURCE: konica minolta bizhub 350
• The Fusing Roller Sub Thermistor does not
detect the required temperature within 30 sec.
after a warm-up cycle has begun; therefore, the
copier does not complete the warm-up cycle.
• The temperature of the Fusing Rollers does not
reach the required level even after the set period
of time has elapsed during a warm-up cycle.
Check that the H1[ fuser lamp] comes on when the Main Power
Switch is set to ON, and correct or replace as necessary.
Check that the H2 comes on when the Main Power
Check the installation of the TH1 and the TH2, and
correct or clean as necessary.
Check the operation of the TH1.
Remove CN80 (4P), and then check that the resistance
across CN80-2 and -3 on the Thermistor is
infinity.
5
Check the operation of the TH2.
Remove CN81 (4P), and then check that the resistance
across CN81-2 and -3 on the Thermistor is
infinity.
6
Check the continuity of the H1.
Correct or replace as necessary.
7
Check the continuity of the H2.
8 Change PU1 - -
9 Change PWB-A
SOURCE: bizhub 250. error c2152
Check and make sure there are no jams by the fuser ie: bits of paper in the paper path.
SOURCE: desbloqueo del codigo m2 en konica minolta bizhub 163
Este código significa que la vida las partes de su desarrollo + unidad de imagen se ha caducado. Ahora es el momento de reemplazar las partes.
