Mixer won't start. Fell on its side and on/off lever was bent. Straightened and it now moves back and forth as it did before. I took out the two black screws at the top which hold in magnets on...
Get A Copy of the Repair Parts List from Kitchenaid.com
Make sure the Speed Lever and and the Speed Link are in place
and operating smoothly. The two Large black screws you are referring to
are the Motor Brushes Caps. The Carbon Brushes are keyed and
designed to be inserted into the Motor Housing but one way. If you
insert them in wrong, they will not make contact with the Motor Coils
and you mixer will never run.
All you have to do now is adjust the mixer speeds (if necessary):
Remove the screw holding the End Cover and locate the three screws from the Control Plate.
All three (2 top left and right, and 1 bottom) must be adjusted.
1. Loosen the lock nuts enough & Turn the 2 top screws clockwise until they cannot be turned
anymore. Leave the bottom screw alone for now.
2. Use a dab of white paint or paper whiteout to mark the positions of the Phillips screws.
3. Plug in your mixer and Set the speed selector to "Stir".
4. Turn each top screw One full turn couterclockwise (alternating between Left and Right)
Keep making one full turn at the time (for both left and right) until the motor starts running.
5. Put your hand near the Agitator shaft and allow it to brush your finger slightly. Use your
watch or clock and start counting the number of times the shaft touches your finger in
60 seconds. The correct count should be 60 RPM (Rounds Per Minute). If it is less
or more than 60, give each screw 1/4 turn counterclockwise or clockwise and start counting
again. Now tighten both lock nuts.
6. Set the speed selector to "6" and turn the bottom screw either clockwise or counterclockwise
to achieve a speed of 180 RPM.
For your reference, the planetary RPM's for the 5-qt. tilt-head Artisan Stand Mixer are as follows:
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
