Can someone please walk me through the process of changing the band on this watch? Thank You.
SOURCE: Repliciment wrist gand for Casio Pathfinder
you can go to this link and in the upper right corner type in the model number not the module number (there are instructions for finding the model number if you don't know it) I found a band for a watch that is over 8 years old on here.
http://www.fsiwebs.com/shopcart3/SC_ProdList.asp?
SOURCE: change casio g shock resin watch band
It can be done and not too difficult i think but look out that the leather band ain't too wide for the band orginal place,
make sure you keep all original parts in case of toruble
Post a photo if you can after the change will be nice to see the change
Tom
SOURCE: how do i change watchband for casio bg169wh
Take the watch with the broken watchband and place it on the table. With a ruler, measure the width of the broken band at the point where it is attached to the watch. Now, measure the total length of the watchband when it is in one piece and fits around your wrist. There will be a crease on the band where it is normally buckled.
SOURCE: casio pathfinder SPF 70-s titanium band adjustment
I purchased a Casio Pathfinder solar/atomic watch, with compass, altimeter, barometer, thermometer, model 1200T-7WC (titanium).
Has the titanium band - on this particular band each link is somewhat waveshaped {i.e., there are 2 "arms" from the link making contact with the middle part of the link above (above meaning towards the watch body), and 1 arm fitting between the 2 arms of the next link down). Unlike described in the first solution, the pin is not split, but solid (doesn't look like a slotted screw on 1 end, so the solution at http://www.wikihow.com/Adjust-a-Casio-S-935L-Watch-Band is no help). Here's what to do if you have this band:
1. Note: before you start, be advised there is a tiny loose 1/8" part (sleeve) that will fall out as you pull the links apart, so work over an appropriate surface to "catch" it. Push pin (from the upper "arrow end) of one of the removeable links (those with the arrows on the backside) out of its hole with a fine poker (I used a 1/32" jeweler's screwdriver, an unbent paperclip would also work, just more likely to bend as you push pin out). This takes some force to do - in my case, after pushing, the pin projected out about 1/2 of it's length, I used needle-nosed pliers to gently pull it out the rest of the way). CAREFUL - once pin is removed and you pull the link away from the one above, a small (1/8") constriction sleeve should fall out of the center arm of the link above. SAVE THIS SLEEVE!
2. Using the same procedure, remove the pin from the bottom end of the link you're removing. again, SAVE THE SLEEVE.
3. to rejoin the band once the link is removed, look at the single/middle "arm" of the upper link, looking for the hole where the pin goes through. One side of the hole should be noticeably larger/wider than the other side - this is where you will place the SLEEVE - I used tweezers, or needle-nosed pliers will work - it will drop into hole. Keep this upright so that sleeve doesn't fall out, and slide the 2 arms of the lower link in place around the center arm.
4. Slide the pin you removed into one of the outer link arm holes - I found it easier if I started from below, pushing it into the center arm - it will stop when it reaches that 1/8" constriction sleeve. I set the extruded end on the pin on a magazine (i.e., slightly padded surface) and then pushed the top side of the band down, forcing the pin through the constriction sleeve and up into the upper arm hole, and Voila, your band is reconnected. The sleeve is important (without the sleeve in place, the pin will simply fall back out).
SOURCE: I have a Casio Pathfinder PAG-70 that reads
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all CASIO watch manuals.Rate me, please
Choose a quiet, well-lit room where you can replace the battery in your Casio Pathfinder watch. Prepare a table, desk or other clean, flat surface where you can perform your watch repair. Put down a soft cloth or piece of craft felt to protect the face of your Casio Pathfinder watch from being scratched during the battery installation process.
Set your Casio Pathfinder watch face-down on the soft cloth or craft felt. Use an optical-sized Philips screwdriver to remove the four screws that secure the watch back to the body of the watch. Set the screws aside, but don't lift the watch back.
Slide the watch back off of the body of the watch very slowly. There are three important springs held underneath the watch back; it is essential to remove the watch back slowly to avoid losing them.
Lift the three springs out of your Casio Pathfinder watch using a small pair of metal tweezers. Take note of the length and placement of the springs as you remove them. Set the springs aside with the other disassembled watch components.
Take the black rubber protective disk out of your Casio Pathfinder to reveal an identically-shaped white plastic disk. Remove the white plastic disk and set it and the black rubber disk aside. Use your metal tweezers, if necessary, to lift out the rubber and plastic disks.
Release the battery strap that holds the battery in place in your Casio Pathfinder watch by pushing the battery strap latch to the left. Remove the old battery from your Casio Pathfinder using a pair of small plastic tweezers.
Pick up your replacement watch battery with the small plastic tweezers and insert it into the battery compartment of your Casio Pathfinder watch. Replace the battery strap and push it gently with the tip of your plastic tweezers to snap the latch in place.
Touch the "-" and "AC" terminals on your Casio Pathfinder watch with the tips of your metal tweezers for at least two seconds. This helps ensure that your watch will work properly once reassembled.
Put your Casio Pathfinder back together to complete the new battery installation. Start by replacing the white plastic disk, followed by the protective black rubber disk. Use your small metal tweezers to replace the small watch springs in their correct locations. Replace the back cover of your Casio Pathfinder, insert the four screws and tighten them with your optical-sized Philips screwdriver.
