20 Most Recent
Casio Sea Pathfinder SPS2011V Wrist Watch Questions & Answers
Casio illuminator, w-94h
There is a tiny spring that must make contact with the back cover plate when you screw it back on. If the spring is missing, the piezoelectric buzzer will not work. The tiny spring is located toward the upper right in this photo of a Casio W-94H watch, directly underneath the "C" in CASIO that is etched in the metal. Note that the word CASIO is upside down in the picture, so if you can't see the picture for some reason, the hole for the tiny spring would be directly above the "C" in CASIO.
10/14/2012 2:44:48 AM •
Casio Sea...
Answered
on Oct 14, 2012
How to reset 2872 casio ?
If a Casio watch has a display readout that says "OPEN", the watch isn't closed properly. Check if all the parts are inside the watch and make sure the watch is tightly screwed shut. If the watch was serviced at a repair center you should return it to have it checked (for missing parts).
After 5 days of darkness, watch will not turn back on
The watch has a rechargeable power cell inside the cover. Remove the back, find the button batter, and replace it. It may be the old original or dead cell. Once you replace the cell, the watch will refresh and be back to normal. The only problem if that fails, the mini-computer brain died.
