First step is connect an external keyboard in USB port. Click start button, type "keyboard" in "search programs and files", in control panel, click "keyboard". In keyboard properties,, click Hardware tab, click properties button. click the driver tab in Standard 101/102-key or Microsoft Natural PS.......Check the button the if keyboard is Enabled. Or you can update keyboard driver through internet or in your original Acer CD Driver software.
SOURCE: acer aspire 5610 keyboard replacement
1. you need to remove the power cover (if you see the power button, that what i mean).
2. after you remove that cover, you will see 2 screw that hold the keyboard. Remove both screws.
3. Remove keyboard and replace it with new keyboard.
SOURCE: can i change my acer aspire 5720z keyboard
Yes you can and here is how
www.youtube.com/watch?v=FoTwln2SyQ4
SOURCE: can't find keyboard for acer aspire 5515-any other model same sz
I'm not 100% but the 5500 series all use the same board. What is the DFE model number on the back of the keyboard?
If you can't find a keyboard for it, you could always use a USB desktop keyboard until you find one.
Testimonial: "I have to look what the DFE # is, hopefully i can match it up that way since i can't find any parts for model #5515. Thank you"
SOURCE: i have an acer aspire one and somehow disabled the
if you can ..go to device manager by right click on the my computer than properties/hardware /device manager
here you have to locate the keyboard ..if it is not present ..just right click on computer and hit scan for hardware changes.. this will bring it to view...after that install it by right click and update driver ...it will find the driver that was before...
if any problems interfere and this will not be possible ...just go to bios...(using a usb keyboard if this one will not work in bios) click to optimal factory defaults )
this will enable it but may not be installed...reboot without the usb one in ...and let it be installed...by windows...
in the last resort if not even one of these works ..just reinstall windows..this will fix all..
SOURCE: acer aspire 7540-1284 keyboard replacement
If you want to replace your keyboard, buy keys and replace it, if you can't replace it by yourself, take it to somebody knows how to replace it.
