20 Most Recent Acer Aspire 5315 Notebook Questions & Answers
if you want to restart your computer you can push Alt and f10 as soon as you see the acer logal. just push alt then f10 then alt then f10 untill it comes to this page where you can restart your computer but it will be set back like if you just got it and if it came out of the box so everything will be erased
Acer Aspire 5315... | Answered on Feb 05, 2019
acer aspire 5315 wont turn on, but the battery led lights up when the ac adaptor is connected..pls help.
Acer Aspire 5315... | Answered on Apr 12, 2018
It looks like your hard drive's failed, you don't say which Windows you're running ? Have you tried a recovery disc?
Acer Aspire 5315... | Answered on Feb 15, 2018
http://www.nodevice.com/
Acer Aspire 5315... | Answered on Dec 11, 2017
CHECK WITHOUT BATTERY IN ADAPTER MODE ,PROBLUM SAME SO CHECK ON ANOTHER OS ,PROBLUM SAME SO UPDATE BIOS OR NOT RESOLVED TO MAINBOARD FAULTY .
Acer Aspire 5315... | Answered on Aug 31, 2017
if the first answer doesnt work well. Run driver pack solution 2013 on ur laptop.
Acer Aspire 5315... | Answered on Sep 06, 2016
your best bet is to try delelting your upper and lower filters. if that doesnt work, the next step is to format.
http://support.microsoft.com/kb/929461 thats a link for a walk through for the filters
Acer Aspire 5315... | Answered on Aug 13, 2016
make sure have installed the drivers for microphone http://www.driverscape.com/manufacturers/acer/laptops-desktops/aspire-5315/619
Acer Aspire 5315... | Answered on Jun 03, 2016
Go to the manufacturers web site and down load one for free.
Acer Explore Beyond Limits
Acer Aspire 5315... | Answered on Mar 06, 2016
Registry Cleaner for Windows uFlysoft Registry Cleaner is freeware, the powerful combination of registry cleaner and system optimizer for Windows. Cleaning registry errors, removing junk files, running a registry defragmentation and system optimization, it can effectively speed up your PC and protect it from crashes, slowdown and errors. Make registry cleanup and system maintenance easier than ever!
  • • Totally free to scan, clean invalid registry keys and repair registry errors.
  • • One click to optimize your Windows system.
  • • Restore feature makes it more convenient and safe.
  • • Also serves as free uninstaller, sartup manager etc.
Registry Cleaner for Windows Help You to Repair Registry Errors
Acer Aspire 5315... | Answered on Oct 21, 2015
You must type the correct password first.
Acer Aspire 5315... | Answered on Aug 01, 2015
Totype the Euro sign in Windows, you press the alt key+0128. As for the Sterlingpound symbol, you can type it by pressing the alt key+0163. You can have a lookat this site where it lists ways to type currency symbols.
http://www.fonts.com/fontent/fontent_home.asp?nCo=AFMT&con=fyti_currency
Please note that you have to type the 4-digit code on thenumeric keypad (do not use the normal number keys) while holding down the Altkey.
Acer Aspire 5315... | Answered on Jul 17, 2015
you could download a dll fixer tool online.just google it
Acer Aspire 5315... | Answered on Apr 27, 2015
Hi Bonnie,
You should check Windows 7 Control Panel's device manager. See if the sound is disabled or if it indicates that it "has a problem" Try to re-enable it - or failing that - uninstall the sound card and click the box that says "remove files". Reboot with an internet connection (wifi or wired). Let windows detect the "new" sound hardware. Check any hardware volume control and set to a mid - high level point. After Windows downloads and installs the driver - follow instructions - reboot if asked. Then test the sound. Check software volume controls in control panel and verify that the sound is enabled. Try using the headphone jack if internal speakers are not producing sound. Once sure that the sound card is loaded, enabled and volume is set to mid - high and neither the internal speakers or external headphone do NOT work, you can consider selecting a new sound source that can use a USB port or PCMCIA (PC Card Slot) depending on your needs and port / slot availability on the laptop. Links below for both styles. Good luck!
pcmcia sound card Google Search
USB sound card Google Search
Acer Aspire 5315... | Answered on Apr 09, 2015
try going into your display setting and reset from there.
Acer Aspire 5315... | Answered on Apr 05, 2015
try going into your icon,,my computer,double click on it and it will open were you will see your cd player icon.right click on it and at the top it will say open click on that and your tray will open...or it should.
just push the try in and let it go and it should open its self
Acer Aspire 5315... | Answered on Mar 29, 2015
just push on the door and it shouldopen a bit then just pull it out
Acer Aspire 5315... | Answered on Mar 22, 2015
Acer Aspire 5315 Notebook Logo
2,268 questions posted
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
View Most Popular
Aspire Acer
  • Aspire Acer
Most Popular Question
looking manual please
  • Computers & Internet
