You checked the charging voltage at the battery with a ? volt meter ? What was the voltage with the vehicle running ? 13.1 to 14.1 volts ?
BATTERY NOT CHARGING
The IPC illuminates the battery not charging indicator in the driver information center when the following occurs:
The PCM detects that the generator output is less than 11 volts or greater than 16 volts. The IPC receives a class 2 message from the PCM requesting illumination.
The IPC determines that the system voltage is less than 11 volts or greater than 16 volts. The IPC receives a class 2 message from the body control module (BCM) indicating the system voltage
Charge Indicator Always On
Step
Action
Yes
No
Did you perform the Diagnostic System Check for Starting and Charging? yes or no
Go to Step 2 yes
Go to Diagnostic System Check - Engine Electrical no
- Turn ON the ignition, with the engine OFF.
- Observe the Charge indicator on the instrument cluster (IPC)
Does the charge indicator illuminate?
Go to Step 3
Go to Symptoms - Engine Electrical
- Turn OFF the ignition.
- Disconnect the generator connector.
Go to Step 4
Go to Charging System Test
Test the charge indicator control circuit for a short to ground. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Did you find and correct the condition?
Go to Step 6
Go to Step 5
5
Replace the PCM. Refer to Powertrain Control Module Replacement in Engine Controls 4.2L.
Did you compete the replacement?
Go to Step 6
6
Operate the system in order to verify the repair.
Did you correct the condition?
System OK
Go to Step 3
