20 Most Recent Razor E100 Electric Scooter Questions & Answers
First try and see if those battery were dead and try a different kind. If that doesn't work notify the person you bought it from or the store about it and ask for a trade in.
Razor E100... | Answered on Jan 29, 2019
You threw away a perfect scooter you idi0t. Needed to desulfate battery with a smart charger. M0ron.
Razor E100... | Answered on Oct 28, 2018
Then the batteries are worn out, simple as that. Just because the batteries are charged doesn't mean they accepted the charge, a common mistake. Go to ebay and you can find a replacement battery most likely/
Razor E100... | Answered on Sep 07, 2016
Tip
How to extend the battery life of Razor Scooter Batteries
You can extend the life of your scooter's battery if you take proper care of it. Most people report trouble in getting more than a year or two out of their razor scooter battery set. This is actually a common problem with vehicle batteries.
  • Keep your battery charged
It is recommended to keep your battery fully charged to avoid the build-up of sulfate-ion inside it. Sulfate-ion accumulates when the battery is in a discharged state for a long time.This is the most common reason of premature depletion of lead acid batteries. This can be easily avoided if the scooter battery is kept in a constantly charged state.
  • Charge you Razor Scooter Battery during the Off-Season
Even if not used Sealed Lead Acid Batteries will self discharge over long periods. This will leave the battery in a not fully charges state which will enable the sulfate-ions to build up inside the internal plates which will slowly deplete the battery's capacity. In order to prevent that, you should charge the razor scooter battery at least once every three months when it is not in service.
  • Use a Battery Tender
Battery Tender chargers are a great way extend the life of your SLA batteries as they are designed to fully charge and maintain a battery at proper storage voltage without the damaging effects caused by trickle chargers.
References:
Battery Maintenance 101 How to Extend Battery Life of Razor Scooter...
BU 804b Sulfation and How to Prevent it
Deltran Battery Tender
on Jun 19, 2015 | Razor E100 Electric Scooter
I HAVE THE SOLUTION!! No, it's not what you're going to want to hear, but I have it nonetheless. The cheapest and easiest way you're going to fix this issue is by firmly grabbing the scooter, hoisting it directly upwards, clearing the rim and depositing it into your nearest refuse container. This is junk at its finest, brought to you from the worst in value and service, the Razor Company.
I did a little investigation into this problem as I too experienced what everyone that owns a Razor scooter does; it works for about two months, then suddenly the "battery stops holding a charge". You can Google Razor scooter issues and get page after page of this happening, along with more pages of frustrated people learning Razor won't do anything about it. But I digress.. back to the facts..
I need not repeat what I've already posted with regard to the issues surrounding my scooter, purchased Dec. '08 as a Christmas gift and not ridden (midwest snow) until the last month or two tops. So as I posted previously, it stops working and I'm assuming it's the batteries. I call my local Batteries Plus store and they say they can help. Here's where it gets interesting.
I bring in the entire scooter and charger. Let me say that I found the charger included in with my scooter.. "interesting?".. as directly underneath the red/green lights there are Chinese characters instead of English words, thus I never had any idea what these lights indicated. That notwithstanding, the test the charger on the spot and tell me it's working and is (pay attention here) 41 volts of charge. This means nothing to me at the time. I learn that testing the batteries in the scooter will take a couple days and they say they'll call with the results.
Before leaving, one of the CSR's engages me in a conversation about his identical experience with the Razor scooter he got for his kids one year prior. The circumstances mirrored everyone elses: it worked for 2 months, stopped working, he checks the batteries, replaces them, still doesn't work, he pitches it. Hearing this isn't making me feel any better.
So the weekend passes and here on Monday I get the call from Steve at Batteries Plus. Here's what he finds: There are 2 batteries in the scooter; one is at 60% of its life (this after a mere month of use) and the other is overcharged and 'swollen'. How can this be I wonder? I followed the charging instructions provided with my scooter TO THE LETTER, never leaving it charged for an extended period, etc. Well the answer is simple- the batteries for this scooter are 24 VOLT BATTERIES being charged by a charger that is outputting 41 VOLTS!! ALMOST DOUBLE THE VOLTAGE! It's overcharging the batteries and frying them out.
Steve said he removed and replaced the batteries with 2 brand new fully charged 24 volt batteries and it still didn't work. He surmised the switch that activates the motor, which is run through the charging system, was fried during its last overcharging.
Ergo, the charger included with these scooters is frying the scooters out in a very short period of time. To replace the charger, both batteries, and the switch would be more expensive than just pitching it and buying another brand new one.
This issie is Razor's fault and they should be willing to fix the issues (cue laugh track here). Go to their site and be ready to laugh at yourself for even bothering. Here's what I found. First I click the 'service/repair' tab, then am directed to the 'Razor Service Center Locater' to find the nearest service center to me to have it repaired. I entered my zip code and it said 'Sorry, no results found'. I then try my city/state, and again get 'Sorry, no results found'. Not looking good.
I then begin reading their return policy. It has a warranty that's good for 90 days from the DATE OF PURCHASE. Naturally, in my case I bought it in Dec. but since there was snow on the ground it was useless until spring; I was screwed before it even was given it's first charge. However, for the regular customer they'll find that even so, it's right at about the 2nd/3rd month when this thing takes it's final ride and as such, and through no fault of your own, your're totally screwed.
There are enough complaints on this scooter on the web that at minimum contacting the BBB is in order, and might I suggest a potential class-action lawsuit? This scooter retails still at $149, and like most of you I don't have $149 to throw in the trash every couple of months only to go and repurchase another "disposable" scooter.
So there it is. Not only are the batteries being overcharged and shot, but collateral damage to the electrical system is being done which is frying the switch that engages the motor and other things. Have your charger checked at your local Battery Plus (no charge) and you'll see they are putting out a defective product, and based on several hits on the internet they are clearly aware of it and do not care.
Razor E100... | Answered on Feb 27, 2015
Your scooter is dying the slow death that all Razor scooter owners are suffering. See my related post on this. Anyway, here's the deal..
I purchased my Batteries on E-Bay.
Make sure the Batteries they offer come with a Square Trader Warranty.
Purchased from Roanoke, Virginia ID hcbaker
Razor E100... | Answered on Feb 13, 2015
Razor E100 Electric Scooter Logo
245 questions posted
Top Razor Toys Experts
Bryan Mcphee
Bryan Mcphee
Level 1 Expert
William Erickson
Are you a Razor Toy Expert? Answer questions, earn points and help others
View Most Popular
Razor Toys
  • Razor Toys
Most Popular Question
schwinn s180 will not shut off throttle
  • Toys
