Linksys Wireless-G Broadband Router Logo
A
Anonymous Posted on Jul 11, 2014
Linksys wireless EA3500
Forgot my ID & password for Linksys Wireless EA3500. How can I get it back, or reset>
Prashant M
Level 3:
  • Linksys Master 2,278 Answers
  • Posted on Jan 31, 2019
Prashant M
Linksys Master
Level 3:
Answers
2278
Questions
Helped
978544
Points
6246
Are you looking for wireless network password? or router password?
if you are looking for wireless network password then you can simply login to Linksys EA3500 router setup page and check the wireless settings.
If you have already installed Cisco/Linksys Connect software on any of your main computer then you will find all the router settings using Connect software.
Remember, if you reset the router, it will come back to factory default settings and you will need to reconfigure it.
Here is link which may help you.
https://fixhomenetwork.com/blog/linksys-ea3500-router-setup-and-reviews/
Robert
Level 1:
New Friend:
  • Contributor 45 Answers
  • Posted on Jul 27, 2014
Robert
Contributor
Level 1:
New Friend:
Answers
45
Questions
0
Helped
8562
Points
87
Press the reset button located on the back of the routed. It is a small hole. Use a straightened paper clip and hold it pressed for 10 seconds. The routed will be reset to the factory settings wi no wireless security
Michael Davidson
Level 1:
New Friend:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Jul 15, 2014
Michael Davidson
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
5
Questions
Helped
424
Points
10
Press and hold red reset button on back of unit for 30 seconds
5 Related Answers
Anonymous
  • 2961 Answers
  • Posted on Oct 09, 2007
SOURCE: Password protection for my linksys wireless router
you need to get into the routers settings and look in the menu for security and select atleast WEP security and either you type a password in to reveal a 8 digit code or type in your own mixture of numbers and letters, which will then have to be entered into each pc when they try to connect. You can also look in the SSID and remove the name or dissable SSID so as your network will not appear on anybody elses wireless searches.
Anonymous
  • 556 Answers
  • Posted on Dec 16, 2007
SOURCE: password for linksys
There is an administrative password to keep people from changing the router configuration.
And then there is wireless security (encryption with a passphrase or key -- like a password both your router and your wireless adapters know and others do not) to keep others from using your router----
First you must choose a common encryption strategy for your home network1.gif. (Yes I am assuming Home Network)
In most consumer routers you activate encryption on the wireless1.gif services of the router. After doing so you must also actiate encryption services on the wireless adapters1.gif that communicate with the wireless router. The names of the encryption services in the wireless router and wireless adapter are WPA and WEP. It is important to assure all wireless adapters to connect to the wireless router can handle the encryption chosen because the router will only perform one. There are options within each technique such as the number of bits of the keys -- the longer the better but only as long as the shortest device can support. WPA is preferable to WEP because it was designed to correct weaknesses in the WEP standard and implementation. However if there is even a single device to be connected that cannot do WPA you must do WEP or replace the device WPA in home systems often have a couple of other attribute being WPA-PSK and algorithm of TKIP -- which again every wireless adapter and the wireless router/access point must support.
To procede further in a sane manner you need to identify all wireless devices1.gif that will participate in your wireless network1.gif and determine their capablities for encryption. This is generally done searching manufacturer websites under support looking for user guides and firmware updates. Sometimes a devices capabilities in the manual require firmware updates to be true for the device. Once that is figured out the standards for your network can be set and the actual implementation can proceed. You will probably want a working wired computer to maintain access to the outside world for assistance if anything goes wrong. You also want to track your changes and know how to back things out incase things become too difficult.
If you have any additional questions or would like to a review of your plan or assistance determining a plan gather up the appropriate manufacturer's names and models and I will assist as time permits.
I hope this helps.
luiskiev
Luis Moreira
  • 144 Answers
  • Posted on Nov 07, 2008
SOURCE: How can i reset my Linksys Wireless-G2.4GHZ Broadband Router settings
Try to reset the router. This should resolve your problem. That model has a small hole were you must press with some a paper clip for exemple for a few seconds. This will reset the router to its original state.
mbase213
Mark Taylor
  • 728 Answers
  • Posted on Dec 12, 2008
SOURCE: resetting my password for my wireless-g broadband router w/ a mac
 If it has been reset the password for the default linksys is admin.
Anonymous
  • 550 Answers
  • Posted on Jul 22, 2010
SOURCE: forgot password for wireless router
Are you speaking about the password of the router or the password of the wireless network ?
If you don't know the password of the router , then you will need to reset the router and use the default password of the router.
Once you reset the router, you will need to reconfigure it.
If you are looking for the wireless password, you can find it on the set up page of the router.
You will need to open the set up page of the router.
Click here for step by step instructions
2answers
Forgot user name & password to Linksys wireless EA3500. How can I retrieve it?
did you change the username and password on the router
if not
1) it maybe written on a label on the router
2) often it is
admin
admin
if you changed it , then you could try using the factory reset button on the device to return to factory settings
If the router was supplied by your broadband supplier they may have setup a username and password themselves and in which case you would need to contact them
WiFi connection issues
I think you can try to reset the router and reconfigure it.
Press and hold the reset button on the router for 30 seconds. Release the button. Unplug the power and plug it back it. Wait for 30 seconds.
Connect the modem to the Internet port on the router. Computer to port 1 on the router.
Open the setup page of the router using 192.168.1.1 and configure the router manually.
Check this article for more information about Linksys EA3500 router Installation
Apr 10, 2014 • LG BP530
Change admin username password
Reset the factory to "factory" settings.
This reverts to the original ID/password.
Then, you can "setup" the router (ID/password/SSID/security).
2answers
Forgot user name and password need to add new
Sorry but this is the only to reset the password
Press the Reset Button for approximately 10 seconds
Resetting the Router will erase all of your settings (WEP Encryption, Wireless and LAN settings, etc.) and replace them with the factory defaults.
I cannot access my WEP Hex Key, how can I locate it or reset it?
Connect to the router with an ethernet cable. Use a web browser and connect to 192.168.1.1 You should see a router home page. login as admin (default id= none/blank/null password=admin) These detailed instructions may help here http://nabtron.com/forgot-linksys-wrt54gr-password-how-to-reset-settings-of-the-router/180/ browse to the wireless/wireless security section and set up your WEP key. You can preview the web page layout here; http://ui.linksys.com/files/WRT54G2/ e.g. http://ui.linksys.com/files/WRT54G2/1.0.00/WSecurity.htm for you this would be http://192.168.1.1/WSecurity.htm
2helpful
2answers
I forgot my password
If you have forgotten the router password you can reset it.
To do this, turn the router upside down and look for a small pinhole that says reset. Get a stapler and press and hold the reset button for 5 seconds.
The router will reset to factory defaults and you will be able to login again using the default username and password. For linksys routers is "admin" for both fields.
1helpful
I forgot my linksys wireless password. Is there a
try the default password like admin or password if doesn't work
reset your wireless and configure again
Forgot linksys router password
Resetting router will revert back to factory default settings. If you had special settings then you will have to set those back up.
Default password to get into the Linksys routers. Username is blank, password is admin.
You will have to setup the wireless portion again after reset.
1 forgot my passwords for each computer on linksys router 54G
You can press the reset button on the back for a minute and it will reset the router back to default.
Wireless access
Hello, If you haven't changed it from default the ID and Password will be "admin". If it has been changed and you've forgot, there is a reset hole on back. Reset to default. Address would be 192.168.1.1 from there you can change SSID and password or enable WEP or WPA. Hope this helps.
Top Linksys Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
