20 Most Recent Linksys Wireless-G WAP54G 802.11g/b Wireless Access Point Questions & Answers
If thats the case I will assume these things:
- You are seeing the wireless router when you are trying to connect but it still wont let you connect.
OR
- You are NOT seeing the wireless router and want to connect to it.
What you will have to do it go back into the router (hard wired into it) and start over. Make sure you access the wireless setting and ensure the settings are compatible with your wireless laptop. If your laptop is very new then the setting at the bottom will work if your laptop is older then the options like WEP/WAP Personal setting will do. Make sure you write down the settings you used for refrence later.
When you rename the device, wirite it down too!
Ensure you "Apply" all the settings and "Logout."
When you are done, go to "Start," "Control Panel," "Network and Sharing Center," "Set-up a connection or network," "Manually connect to a wireless network," and enter all the information you wrote down!
Let me know if there is anything else you need help with!
-paul
Linksys... | Answered on Sep 11, 2016
Login to the router to change the wifi key
Linksys... | Answered on Feb 22, 2015
Login to the router web page to view or change the encryption key
LOST WIFI SECURITY KEY WORD
If you have lost your WEP/WAP wifi key phrase there is no way to recover it except go into the router administration settings and see if it is in plain text there. If not then you will have to make up a new key phase and apply it to ALL your connected devices.
In future, write the key phrase down on a piece of tape and apply it to the bottom of your router. You can use a hint instead of the actual phrase.
I use the memo function of my cell phone to keep all my passwords and keys.
Linksys... | Answered on Jan 29, 2015
excuse me guys i got a problem with this device
Seirra wireless AT&T mobile hotspot elevate 4G 705s i want to unlock code or unlock code ! i bought it from america
support 800-331-0500
imei 012701003466959
version SWI9200H_03.05.09.06AP
PLEASE help me
this my e mail: nui3531n@yahoo.com
Linksys... | Answered on Apr 13, 2014
Hi There - in my experience, blinking power lights on routers mean faulty power supplies - the Power Adaptors are prone to failure after long periods of continuous use - I would find out what voltage and current consumption is required for your router (usually printed on a label on or near the power socket in very small writing), then buy a replacement adaptor - you don't need to get the exact same item, one which can be adjusted to give different voltages should work just as well if you can match the voltage and power rating your device needs - You can use an adaptor with a higher power rating but don't use one with a lower power rating
Linksys... | Answered on Dec 20, 2013
Try resetting the Linksys router.
To reset the Linksys back to the default settings - Press and hold the pinhole RESET button at the back of the router with the power ON for 20 secs. then release the RESET button.
To connect to your wireless router, the router's wireless settings needs to be configured with the SSID, encryption etc. and also the wireless cards in all the laptops/computers needs to be configured with these router's wireless settings. Then the laptops/desktop computers can communicate with your wireless router.
Connect a LAN cable from the Linksys to the LAN port on your computer.
Open a browser and enter the Linksys configuration URL
http://192.168.1.1
The default login = admin
The default PW = admin
You can protect your router by changing the default admin PW (write it down and put it in a safe place)
Go to the wireless configuration and set up the SSID and WPA or WPA2 encryption to protect your wireless network and Internet from unauthorized access.
Now apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Linksys... | Answered on Mar 03, 2013
I want ching the yahoo password
Linksys... | Answered on Sep 25, 2012
Try this:
On you cellular phone go to the Data Network and turn it off then on. This helps me when I have the same issue. Im using an IPhone.
If you are unsure on how to get to your Network Data reply to this blog and I will try to give you the steps to access your Network Data.
Linksys... | Answered on Aug 09, 2012
Try reseting the Linksys back to the default settings - Press and hold the pinhole RESET button at the back of therouter with the power ON for 20 secs. then release the RESET button.
To connect to your wireless router, the router's wireless settings needs to beconfigured with the SSID, encryption etc. and also the wireless cards in allthe laptops/computers needs to be configured with these router's wirelesssettings. Then the laptops/desktop computers can communicate with your wirelessrouter.
http://192.168.1.1
You can protect your router by changing the default PW (write it down and putit in a safe place)
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Linksys... | Answered on Aug 16, 2011
Seems like intermittent wi-fi issue. Suggest you to upgrade your router's latest frimware
Linksys... | Answered on Jul 11, 2011
You can change the Linksys default SSID to Silver_Home -
Connect a LAN cable from the Linksys to the LAN port on yourcomputer.
http://192.168.1.1
Just hold reset button in back for 30 secs small black hole then goto 192.168.1.1 in your web browser use password admin admin or admin password that should get you in to resetup you wirelss settings.
Linksys... | Answered on Jul 05, 2011
Problaby a hard reset will solve your problem.
There's a small red reset button at the backside of the device.
push it for at least 10 seconds.
Linksys... | Answered on Jun 15, 2011
Linksys Wireless-G WAP54G 802.11g/b Wireless Access Point Logo
209 questions posted
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Linksys Computers & Internet
Most Popular Question
linksys manual
  • Computers & Internet
