20 Most Recent
Linksys WUSB54GS 802.11G USB Adapter Wireless-G With SpeedBooster (Retail) (NTUSLSUSB54G) Questions & Answers
When I restart my computer
It is totally possible that the wireless adapter is just old and not working as well as before.
You should try updating the drivers for it to see if that clears up any issues with finding networks.
If that doesn't work it may be time to start shopping for a new adapter.
My USB Adapter needs the WEP code everytime I switch on.
I can assist you with your issues. I provide Remote IT Support for a very reasonable fee. It appears as though there is an option to save this code in your settings, however I would like to take a look at it.
You can contact me through my website at:
http://www.rapidresponseremotesupport.com
Thank you!
I have a Linksys Wireless-G Network adapter
http://www.linksysbycisco.com/US/en/support/WUSB54GS/downloadYou may want to download drivers and new updates for this model from the link above. You have to select your version (2) and you'll see the download to your left on the page.
Try plugging it into another USB port.and or another computer if you have one available. Test the USB port with another device to see if it maybe the problem. Also make certain your plugs are snugly in their sockets. But it I think you are right on target with the defective device point of view.
If you ruled out the things listed above...defective.
Hope this helps, please leave rating, thank you
Wireless G usb adapter has
hi ganges, at this point there is a possibility that the wireless adapter's drivers where removed, corrupted or just needs an update. please click on the link below to see the steps needed to be done to reinstall the device or perform a driver update.
WUSB54GS Installation
WUSB54GS Driver update
hope this helps, if you have other questions just let me know
Connected to rounter but not internet
Normally this means that you are not putting in the security key or wireless key. Click on the linksys software then go to site survey select your network then click connect and type in the correct security key.
Wireless access
Hello, If you haven't changed it from default the ID and Password will be "admin". If it has been changed and you've forgot, there is a reset hole on back. Reset to default. Address would be 192.168.1.1 from there you can change SSID and password or enable WEP or WPA. Hope this helps.
Signal strength
An omni directional antenna connected to the router will extend the range of your wireless network, it should solve your problem. You can find them in any PCs store.
Frontier router
Frontier Router Login at the bottom of the Network Connections window, just below the address bar. Select Wireless Properties from the menu. Locate the Network security key field on the Security tab. You'll see your Wi-Fi network password if you click the box for Show characters.
1/28/2022 7:46:04 AM •
Linksys...
Answered
on Jan 28, 2022
How to Fix Linksys Router Error 2118?
This seems to be a symptom of a configuration error, which can be fixed by resetting the router to factory default. Do this by finding the (often partially hidden) reset button on the device, and pressing and holding down the button, with the power on, till lights start flashing on the router. Let go of the button and allow the router to reset (can take a minute or two). You will now have reset the router to factory default. To connect to your ISP, you'll need to enter your account details (and any other specific information) provided to you by your ISP. You will also have to set a name and password for the wifi section of your router (if it has wifi) if you don't want it to be freely accessible by everyone within wifi range.
7/29/2021 11:33:41 AM •
Linksys...
Answered
on Jul 29, 2021
Why is my Linksys WRT54G wireless-g router not being recognized anymore?
just fixed one yesterday.
the power pack was no good.AC wall wart,
power green LED blinked endless. and the white logo, LED is dead..
a new pack fixed it.
also the wrong pack used, ! do not mix them up. oops.
first year 54G, v1 uses 5vdc pack.
at v2, and up all want to 12vdc pack,
bottom sticker on above failed was v6.
you said recognized, does that mean the 4 rear Ethernet wired jacks are dead, or just wifi dead.?
first the ethernet ports must work, or wifi is doomed.
2/18/2020 11:46:05 AM •
Linksys...
Answered
on Feb 18, 2020
How to fix Linksys router error 321 ?
Good day,
This might be of help .
Steps To Fix Linksys Router Error 321:-
Step1:- Check the Firewall Settings
To check the Firewall Settings is the first priority for the users. Then check the firewall settings of the computer/ Laptop, will be helpful to find the problem. If there is any firewall installed on the computer, so the users need to turn it OFF.During the process, the users ensure that the Local Area Connection on the computer is not disabled. The Local Area Connection should not have any static IP address assigned. If there is any then the users need to immediately set the IP address to automatic.
Method2:- Run the Installation CD Again:-
The users require trying to run the CD again and ensure when the CD runs, it will ask to connect the computer and the modem to the router with the cable. So the users will need to notice, that there all the lights lit up on the router. If it's not, then users will need to setup their router without the CD.
The users can get the instruction to setup router manually in the method 3.
Step3:- Try to Setup Router Without Installation CD
Setup Linksys Router without Installation CD is another best option for users in order to completely avoid the in order to fix Linksys Router Error 321.
Follow the below-given instruction to Setup Linksys Router without Installation CD:
First of all, connect the main computer to the Ethernet port on the router.
Then the users need to connect the modem to the Internet port on the router.
Now it's time to verify the status of the light that is blinking properly.
Next, users need to open the setup page of the Linksys Router and then change the Internet connection settings manually.
In the setup page of the Linksys Router, the users can change the settings of the router as per their needs.
Then the default IP address of many Linksys router is 192.168.1.1. And the default username and password would be an "admin".
Wait for a few minutes, when the main computer is able to access the Internet, so users need to create a wireless network for their wireless computers/devices.
or you can call them @ Toll Free 1-800-204-6959 that is Lynksys support.
2/3/2020 1:14:25 PM •
Linksys...
Answered
on Feb 03, 2020
