Sharp AL 1631 Copier Logo
A
Anonymous Posted on Jul 11, 2014
Scanner bar won't move on sharp ar-162 copier
Tareq Bin Mostaq Mostaq
Level 3:
President:
  • Sharp Master 1,449 Answers
  • Posted on Jul 17, 2014
Sharp Master
Level 3:
President:
Answers
1449
Questions
31
Helped
614581
Points
3628
Problem on scanner motor
5 Related Answers
Anonymous
  • 62 Answers
  • Posted on Mar 23, 2008
SOURCE: Sharp Copier Service Code
You had 5 jams in the fuser the hotarea on the left side of your machine.
Anonymous
  • 6966 Answers
  • Posted on Nov 17, 2008
SOURCE: Sharp AR-5320 Driver
Appreciate the direct "Ask Me". For Sharp AR5316/AR5320 drivers, pls click here. The drivers are for Windows 95, Windows 98, Windows ME, Windows NT, Windows 2000, Windows XP only.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Anonymous
  • 115 Answers
  • Posted on Nov 22, 2008
SOURCE: Sharp -COPIERS - AR-5316
@subscribe
Sharp does offer a linux driver, look for a cups driver.. Sharp offers drivers for mac, linux, hp output servers, as/400, windows etc... of course this varies on model number...
san3409jl
  • 190 Answers
  • Posted on Jan 27, 2009
SOURCE: error code Sharp AR-M 257
The F2-04 error code you are getting is that you are using the wrong toner.It may be form sharp,but it toner chips is different.Only the chips swapping at the toner back can help you.
Anonymous
  • 7 Answers
  • Posted on Jun 10, 2009
SOURCE: I have a sharp copier, model AR-285, H4-01
H4 error pertains to lamp errors.
that would either be the copy lamp or the heater lamp.
check both lamps.
with heater lamps,it's usually caused by either a broken heater lamp or a dirty thermostat on the heater roller assembly.
How do I print both sides of a document on legal size paper?
tell the copier you have a two side orginal. then scan one side then scan the other
try this site
http://siica.sharpusa.com/product-downloads
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Code F2-04 solution
http://www.retrevo.com/support/Sharp-AR-M162-Multifunction-Printers-manual/id/600ag113/t/2/
Above is your user manual below is your service manual.
http://www.eserviceinfo.com/index.php?what=search2&searchstring=AR-162,+AR-163,+AR-201,+AR-206,+AR-207,+AR-F201
http://www.eserviceinfo.com/fulltext.php?search_ft=DPX-7010MD
You have a sensor error. I have included your user and service manuals so you can attend to the error.
F1-04 Bin limit position sensor error in sorter
1helpful
Erorr L1 Apears in the display
L1 IS USUALLY TO DO WITH THE SCANNER POSITION CHECK THAT THE SCANNER LOCK SWITCH HAS NOT ACCIDENTLY MOVED CAUSING A LOCK YOU CAN CHECK THIS BY LIFTING THE LID AND TURN THE MACHINE ON AND OFF IF THE SCANNER IS FREE YOUN WILL SEE IT MOVE TO THE HOME POSITION.
1helpful
H2-00 CODE
Hello sir; It is a reset procedure need;
press"clear", "interupt", "0", "interupt", then enter 14 press print, will set.
Error CE while scanning though N/W in Sharp AR M-205
If subcode is 00 then network connection is problem, if 02, then its not talking to the network scanner tool on the computer. Might be an IP address problem, where the address in the webpage of copier is wrong for the PC.
3helpful
2answers
Error code L1
YOU EITHER HAVE THE SCANNER LOCKED OR THE SCANNER RAIL [SILVER BAR UNDER GLASS NEEDS TO BE LUBRICATED.
27helpful
7answers
3helpful
2answers
Sharp AR-162 Laser Unit
searching for solve problem L6 error in the machine sharp m 160
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
