20 Most Recent Sharp AR-5316 Advanced Digital Imager Copier Questions & Answers
sharp AR 5625 Erreur H3 - 11 ?????
Sharp AR-5316... | Answered 2 days ago
when you open side door in the up you see a black unit check if sesor not broken. also open cassete and see inside no paper jam there
Sharp AR-5316... | Answered on Dec 29, 2018
sharp ar 5516 showing ( - - - ) what's the solution
Try installing the old driver by right clicking and choosing the run in comparability mode I have had pretty good luck getting these older sharps to run on newer operating systems that way.
I’m happy to help further over the phone at https://www.6ya.com/expert/ethan_e84416e0b13809d2
Sharp AR-5316... | Answered on Nov 18, 2018
How are you , this problem occurs when there is very low toner concentration on the unit or low developer.
solution
  1. Replace a toner cartridge and make sure it is smoothly running as some come with hardened toner or
  2. Replace a new developer which is Sharp Ar 205 dv Check that the toner motor is rotating well
This error is self resetting so no need of simulation code. Bye.
Sharp AR-5316... | Answered on Nov 15, 2018
WHEN THE SHARP AR-5316 PHOTOCOPIER IS SWITCHED ON THE ERROR CODE 4H APPEARSAND THE MACHINE CANNOT BE OPERATED. IHAVE TRIED THE SOLUTION SUGGESTED JUNE THIS YEAR BUT IT DID NOT WORK. WHAT CAN I DO TO GET THE MACHINE TO WORK? IT IS VERY URGENT.
Sharp AR-5316... | Answered on Nov 03, 2018
Hi
Error code H2 means fusing unit temperature error. This error occurs due to a bad fuser temperature thermistor or due to fusing lamp. To resolve this error try and reset the unit by entering the service mode--
press # - INTERRUPT - C - INTERRUPT
then
14
start
If this resolves your issue then try restarting the printer and try the reset again. However, if reset is not helping you then you
maintenance reset = crop 20 -01
developer reset = crop 42-01
Sharp AR-5316... | Answered on Oct 15, 2018
try p-*-C-* to get into service mode use code 14 print to reset machine
Sharp AR-5316... | Answered on Jun 29, 2018
hi,I have error code L h on my coppier sharp 5516. your help please.
ERROR CODE U2-4 COULD BE RELATED TO THE MEMORY BATTERY BEING DEAD ON TEH MAIN BOSRD IF IT IS AN OLD MACHINE SO YOU COULD CHECK THSI OR REPLACE AND TRY WITH NEW
Sharp AR-5316... | Answered on May 15, 2018
your chip cartrige is wrong
Sharp AR-5316... | Answered on May 13, 2018
this error means:
heat roller abnormally low temperature.
for check:
1- check the heater lamp
2- check the thermistor
for reset:
clear key --> interrupt key --> "0" key --> interrupt key --> 14 --> start key
Sharp AR-5316... | Answered on Jan 30, 2018
Try reset by pressing [#] [interupt] [C] [interupt] [1] [6] [start]
Sharp AR-5316... | Answered on Dec 08, 2017
main motor gear broken,please change it
Sharp AR-5316... | Answered on Nov 15, 2017
1- replace the toner cartridge.
2- replace the chip toner cartridge.
3- check and fix connection between toner cartridge and mcu pwb.
Sharp AR-5316... | Answered on Sep 16, 2017
You call Sharp Service. There is no way you could fix the problem even if you were told what the codes mean.
You can find that out when the Technician calls to fix it and give you a either a "guesstimate" or a formal written quotation. Either way you will either have to pay a call-out fee, or if you transport it to them, an inspection and quote preparation fee.
Nothing for nothing in this world......sorry !
Poppa
Sharp AR-5316... | Answered on Jun 06, 2017
Sharp AR-5316 Advanced Digital Imager Copier Logo
1,371 questions posted
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
George Mclaughlin
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Sharp Office Equipment & Supplies
Most Popular Question
sharp ar 5516 maintenance reset
  • Office Equipment & Supplies
