20 Most Recent
Sharp AR-M162 All-In-One Laser Printer Questions & Answers
Sharp AR-m162 is printing from my computer but refuses to scan to the computer. It worked fine yesterday.
Run Sharpdesk network scan tool. in low right of your taskbar click on network scan tool
create a profile in profile tab, This will show up on sharp display as an avaiable location to scan to.you can choose where to scan to and what program if any to open when recieving a scan. Next in scanners tab click "auto detect" it will find available sharp scanners on the network. check one you want to use in the box in the list click "ok" close it make sure it is running in the task bar and add it to startup if need be but you should be good to go after this
David
Reset instructions
It's likely that a thermostat has tripped but to reset you can try the following:
Press # * C * quite quickly. When the quantity display goes blank, enter 14 then press the start key. This resets the code but if there is a problem with the thermistor, thermostat or lamp in the fuser the code may reappear.
Good luck
Follow me on Twitter @CDOS_Service
Olá gostaria de saber como
Pegando o cartucho de frente a sua esquerda h? uma portinha com toner, esvazie e jogue o toner fora pois ali ? o deposito de tenoer reciclado.
Na direita do cartucho abaixo das engrenagens h? uma tampinha branca, abra-a e deposite a recarga ali depois ? so tampar.
I have an error code
When your copier heater unite thermostat is out of order then show H5-01 is blinking.
You can reset it Press # interrupt 0 Interrupt press 14 press print key or start button then machine is ready.If are not success you must change it.
Sharp AR-M206 printer is producin an error call
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
- Improper
cartridge (destination error, life cycle error)
Identification error
model error
type error
destination error
data abnormality
Misc error
I am going to be shipping my Ar-m162 today and
You should be able to find the procedure in the user manual, but in general on Sharp copiers, there is a screw hole underneath the scanner on the left hand side where you can insert a screw that came with the machine which goes up into the scanner carriage and keeps it from shifting or jiggling in transit.
If you don't have the user guide, you can probably find one online, and if you don't have the screw, any similarly-sized screw that will fit in the hole should work.
