20 Most Recent
Sharp AR-C260M All-In-One Printer Questions & Answers
Code message
improper cartridge (destination error,life cycle error )
identification error
model error
type error
destination error
data abnormality
misc error
What does the code H4-00 on a Sharp AR-C260 copier
That is a heat error and easy to clear.
On your machine press P * C *. That is the #*C*.
The machine will enter diagnostics. In the small box enter the number 14 and press start, It will then give you an option to press the number 1 to clear the fault.
Once there, enter 1, then press start. Press clear a couple of times and the machine will reset and run.
You could have a fuser problem. But I would say 95 percent of the time doing the P*C* will resolve it.
Will not turn on power
May i help, Test your power source if present.,Check fuse if functional, check power button if damage or broken, Commonly on that unit is the power button may dislocated, so try to see it well.
How do i refill sharp AR-C26TBE
You don't, unless you can find a way to replace the countdown CRUM chip. Besides, those cartridges wear out and put uneven toner on the foam roller. Best to buy a new one.
Network error ce-02 fix
The IP address or computer name your copier has been told to scan to ain't there no more. get rid of all your scan profiles in the NST and web page and resubmit.
