1998 BMW 318i Automatic Logo
Posted on Jul 11, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi I have a 1994 318i BMW Automatic, there sims 2 be problem with shifting from 3 rd to 4 th gear and slipping with that, but if I put it in manual mode than I lose a 4 th gear all 2gether, and the
Hi I have a 1994 318i BMW Automatic, there sims 2 be problem with shifting from 3 rd to 4 th gear and slipping with that, but if I put it in manual mode than I lose a 4 th gear all 2gether, and there is NO warning lights that come on the board? Can any1 help please. Thank you in advance. Anatoli
Ronaldbrains
Level 3:
  • Master 881 Answers
  • Posted on Jul 11, 2014
Ronaldbrains
Master
Level 3:
Answers
881
Questions
0
Helped
299504
Points
2375
Hi there.
Well because its a auto box you could have a band or pump problem which is in the gear box and is bathed in auto matic fluid oil and that could be your problem as the bands do wear down fast on a lot of cars and BMW with there power that could be you.
So take it to a auto box people and get it checked out.
Have 02 traolblazer, shifts thru 1,2 and reverse fine, when shifts to 3rd, nothing , as if in neutral. What could be the problem.
sound like the 3 rd gear clutch pack is bad that is if it is a automatic, if it is a stick shift then 3 rd gear is blown
Peugeot 206 4 speed automatic not shifting correctly. Shifts between 3 rd and 4 th cant work out what it wants to do.
you must check the electrical connectors of each sensor..if fine all..it might be transmission hydraulically failure or each components worn out.
How many qts of oil do i need
Depends on your engine.
1980 JEEP CJ-7 2.5L 4-cyl Engine Code [B]
CAPACITIES
Engine, GM without filter..........2.4 quarts[1]
Wix Filter ........ 51040
Cooling System, Initial Fill..........8.0 quarts
Automatic Transmission, A904, 30RH Initial Fill..........4.0 quarts[2]
Automatic Transmission, A999, 32RH Initial Fill..........4.0 quarts[2]
Automatic Transmission, Total Fill
3 speed A999, 32RH..........8.4 quarts
3 speed A904, 30RH..........7.0 quarts
Manual Transmission, 4-SPD, SR-4..........3.0 pints
Manual Transmission, 4-SPD, T176..........3.6 pints
Differential, Front..........2.5 pints[3]
Differential, Rear..........4.9 pints
Transfer Case,..........4.0 pints
1. Add extra oil when replacing filter. After refill check oil level.
2. With engine automatic transmission operating temperature, shift through all gears.
Check fluid level in NEUTRAL and add fluid as needed.
3. 1984-1992 Models with command-Track, add 5 oz of 75W-90 GL-5 to shift motor housing opening.
TORQUES
Oil Drain Plug.....25 ft-lbs
Manual Transmission T176
Fill Plug.....15 ft-lbs
Drain Plug.....15 ft-lbs
Manual Transmission SR4
Fill Plug.....20 ft-lbs
1980 JEEP CJ-7 4.2L 6-cyl Engine Code [C]
CAPACITIES
Engine, without filter..........5.0 quarts[1]
Wix Filter..... 51522
Cooling System, Initial Fill..........11.0 quarts
TORQUES
Oil Drain Plug.....30 ft-lbs
1980 JEEP CJ-7 5.0L 8-cyl Engine Code [H]
CAPACITIES
Engine, without filter..........4.0 quarts[1]
Wix Filter..... 51258
Cooling System, Initial Fill..........13.0 quarts
TORQUES
Oilman
1helpful
2answers
1st gear is burnt out in automatic trans have to put in L to get going than put it in drive to catch next gear
low is first gear. sound as if d is burnt that is 3 rd gear. you need your trans rebuilt.
2answers
TH 350 transmission question
Thought you had an old "slip & slide powerglide" ! I like the way they originally cursed them, then all the racers wanted them all of a sudden. Anyway, if you have the TH350, which your obviously cruising and shifting manually, just go with gear selection that sounds good to you, RPM wise. I never look at a tachometer, all by ear. The TH 350 are pretty strong too. Then of course there's always a shift kit that will make it bang into next gear & chirp tires for cruising too.
3answers
91 BMW 5251 -A4S310R- auto trans - after engine
my bmw did a similar thing had the shift solenoids replaced never had a problem since as for supply i am in australia so could not advise you i assume you are in the US
Top BMW Experts
vince
Steve Sweetleaf
Steve Sweetleaf
old marine
old marine
Are you a BMW Expert? Answer questions, earn points and help others
