It is a desk top computer
1. Turn off your computer.
2. Press the power button to turn your computer on.
3. Hit F11 a few times quickly, while the launch screen is still up. This will launch the Recovery Manager. (If you see the Windows 7 boot logo, you've missed your chance and need to restart your computer and try again from step 2.)
4. On the left side it will say "I need help immediately". Underneath that there will be an option that says "System Recovery". Click on that.
5. There will be an option to either back up your files before restoring, or to recover without backing up your files. In my case, I'm recovering without backing up my files.
6. It will tell you to make sure all devices are disconnected from your computer. Make sure they are, and then click "OK".
7. There will be a "Welcome to the Recovery Manager" screen. Click "Next".
8. It will begin to reformat your partition and to reinstall the Windows 7 setup files. Once it's done doing that, click "Next". You'll be brought to a page saying "Recovery is Complete". After that all you need to do is reboot, and it will bring you through the wizard to set up Windows 7, just like on a new computer!
Good luck :)
SOURCE: compac V2000
i need to reformat my presario v2000 to factory settings. I put in the xp disk, and went the install xp option, then installed it all and still it did nothing. I have some NETUPGRD.DLL problem, it says. I thought reformat would fix?? can anyone help??
SOURCE: Have compac persario m2000. The power supply will
the issue might be with the power jack . i mean the port where you insert the charger.. to fix this issue your laptop needs to be repaired.
SOURCE: how can i restore a
Hi
Sometimes if you press the F11 or F10 key on startup it can take you to the factory restore
but please remember to save anything important to disk or pendrive because you will loose everything you have put onto your laptop
