HP TouchSmart 600-1120 All-in-One PC Black Logo
A
Anonymous Posted on Jul 02, 2014
Why is a blue light blinking on my HP TouchSmart 600-1120 Desktop PC?
This blue light is on the bottom right side/clock side. It goes through periods of blinking then, won't for several months. I don't use wifi. My pc is hardwired as there is/are serious stalker issues in my life. Could someone please help me with an answer and some peace of mind? Thank you in advance:)
tukevaj
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 20, 2014
tukevaj
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1085
Points
Hi, I don't know if you already figured it out, but the blinking blue light has nothing to do with Wi-Fi. It is the IR signal indicator for the remote control. The receiver is invisible and located down near the blinking light. The fact is, that even if you don't have any IR sending devices nearby, any table lamp might cause a certain wavelength light, that makes this IR receiver think he's receiving and blink the light. Try to switch off all xtra light around you and the blinking should stop... :) Then if you still want to dim the light, find the IR sensor and put enough tape on top of it. This solved my same problem...
Richard Lilja
Level 3:
  • Master 401 Answers
Richard Lilja
Master
Level 3:
Answers
401
Questions
0
Helped
244487
Points
1244
You are seeing the blue light on the bottom of the screen / monitor is indeed the WI-FI indicator led, and when on it means that the pc has the Wi-FI on and when it is blinking it means it is searching for a network to connect to. All you need to do is turn it off using the keyboard. Find the "function " key usually labelled "fn" and sometimes in a blueish color, you will need to hold this button down and then find and press the wireless icon on the keyboard (Usually one of the function keys (F1 to F12)) the blue led should turn off and you are off the air. You don't need it anyways as you are hard wired!
Good Luck!
Rich Lilja
  • tukevaj
    tukevaj Aug 20, 2014
  • tukevaj
    sry, wrote this answer to wrong place...
Bob Sloan
Level 3:
  • HP Master 2,013 Answers
  • Posted on Jul 25, 2014
Bob Sloan
HP Master
Level 3:
Answers
2013
Questions
Helped
356988
Points
8519
If it is in the tray, right-click it, and you can probably see what it is.
5 Related Answers
Anonymous
  • 62 Answers
  • Posted on Jul 26, 2008
SOURCE: HP TouchSmart PC - colored stripes only
remove the power supply to the pc and leave it off for half an hour
Anonymous
  • 2351 Answers
  • Posted on Jan 29, 2008
SOURCE: widescreen resolution...
Every video card has it's max resolution. To see what your max is for the d530, if your running a version of XP. Open Control Panel. Open Display. This will open Display Properties. Click the Settings Tab. Listed there is screen resolution, sliding the marker all the way to More will give you your Max resolution. I have a high end video adapter & my max resolution only goes to 11280x1024. You may have to contact HP/Compaq. The link listed contains updated drivers for the d530 but there is a bunch listed because each d530's have different internal devices.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=316715&prodTypeId=12454&prodSeriesId=316713&swLang=13&taskId=135&swEnvOID=1093#11360
You can chat with HP/Compaq at this link:
http://h20000.www2.hp.com/bizsupport/TechSupport/ContactHP.jsp?lang=en&cc=us&prodTypeId=12454&prodSeriesId=316713
This is your best shot! Good luck.
Please vote...
map
philw1964200
Phil Whisenant
  • 163 Answers
  • Posted on Jan 08, 2009
SOURCE: my screen does not respond on my Hp touchsmart pc IQ 506
Is it still under warranty? It should be. If not then HP will help either way. This is a new development for HP to start with. Go to HP/support.com there are questions there to match up with the problem you are having if not then you can send them you actual problem you are having. They will most likely either pick up your PC at no cost or do a remote access to resolve your issue. Have any problem in doing this let me know and I will help you.
Phil
I’m happy to help further over the phone at https://www.6ya.com/expert/phillip_293d34ebcf028794
Chuck68
Ganesan Chandraiah
  • 42 Answers
  • Posted on Jan 12, 2009
SOURCE: Power light blinks
If Power supply light on or flashes
Perform the following steps, in order, until power is restored or it is determined that there is a hardware failure:
CAUTION: This product contains components that are easily damaged by ElectroStatic Discharge (ESD). To reduce the chance of ESD damage, work over a non-carpeted floor, use a static dissipative work surface (like a conductive foam pad), and wear an ESD wrist strap that is connected to a grounded surface, like the metal frame of a PC.
1. Disconnect everything from the computer, including the power cord.
2. With the power cord disconnected , press the power button on the front of the computer for five seconds. Plug in the power cord and test to see if the computer can turn on. If not, continue using these steps.
NOTE: If the power supply fan makes an inconsistent grinding sound or stops and starts erratically, replace the power supply
3. With the power cord removed, flip the red voltage selector switch to the opposite position. Wait about five seconds, and then switch the red voltage selector switch back to its original location. Ensure that the voltage selector switch is on the correct setting, 115V for North America.
Performing this step ensures that the voltage switch is engaged and set correctly for your country/region.
4. Plug a lamp into the same outlet to see if the wall outlet has power. Try the computer in a different outlet in order to eliminate the outlet as a possible source of the issue. Test both to see if the wall outlets have power.
5. Remove all extension cords, power strips, surge protectors and any converters that remove ground. Plug the power cable directly to the wall outlet. Test for power. If this fixes the issue, find the device that is causing the issue and do not use it.
NOTE: If you find the device that was causing the problem was a surge protector, resetting a breaker or fuse on the surge protector may fix the issue.
6. Remove all attached devices except for keyboard, mouse, and monitor.
7. Remove any internal component that was recently added, such as video card, memory, CD, DVD, and hard drives. An added device may take more power than the power supply is rated for. If the problem goes away when the component is removed, the only option is to upgrade the power supply to power supply with a higher wattage rating.
Anonymous
  • 62 Answers
  • Posted on Mar 19, 2010
SOURCE: HP TouchSmart IQ770 PC Desktop replace screen
Hi ,
I have pasted the url so kindly copy paste it in the address bar and you will find the moving pictures .All u need to do is just roll the mouse over the picture and u will find something interesting ....It gives u the steps to replace the screen...
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01060928&tmp_task=solveCategory&lc=en&dlc=en&cc=us&lang=en&product=3351220
hope this will help u .....all the best...
Hp touchsmart wont power up
It would seem that your power supply has failed. If you can open it you should check all of the connectors inside are tight. Make sure the power is off and the mains lead is unplugged from the wall.
2answers
Hp TouchSmart 310 wont start,power light flashes
The LED light has now turned into a diagnostic light. The fault is a bad Power Supply.
Replacing it however, is easier said than done.
I don't know what exact model of the Touchsmart 310 series you have.
(Examples such as TouchSmart 310-1000Z, or 310-1125f, or 310-1155y, etc.)
The TouchSmart 310 series of All-In-One desktop computers, has a battery, and an AC adapter, (Charger), for power.
Test the battery with a multimeter set to DC Voltage.
{Symbol is a dotted line over a solid line. If there is more than one DC Voltage setting, set it to 0 - 50 Volts }
Should be close to 18.5 Volts (DC)
Battery is low?
Check the AC adapter (Charger)
The middle metal cylinder of the plug that goes into the computer, is Positive.
The outside metal shell which surrounds it, is Negative.
Again, 18.5 Volts (DC)
Check both then post back in a Comment.
Regards,
joecoolvette
I want to connect a HP w2207 monitor to a HP TouchSmart IQ770 PC. What is the best way to do this?
Your HP w2207 monitor has support for both VGA and DVI inputs. This therefore means that you can connect your HP TouchSmart IQ770 PC via either of these two connectors.
VGA is the blue coloured port on the rear of your monitor.
DVI is the white coloured rectangular port located on the rear of your monitor.
DVI is the better connection of the two as it is a digital connection, so use this one if you can, alternatively you can use the blue coloured VGA cable to connect your monitor to your computer.
It all depends on which output, either DVI or VGA is found on your Computer. Remember VGA is the Blue coloured port and DVI is the blue coloured port.
All the best!
damnor01
My screen has blotchiness in the blue areas when first started and goes away when warmed up after about 20 min
This is a know reported issue with Touchsmart PC, This is due to water Vapour, Dont need to worry about this, If possible change the location of the PC.
Hp touchsmart 300 pc
your screen resolution is losted. plz change your screen.
2answers
My ambinent light is blinking on my hp touchsmart. the button on the left on the computer turns the light on and off and has three settings. currently, it blinks through all three settings then turns off...
sounds like either the switch controlling the light is not working or the or the abient light is burnt out causing a short. If under warranty Have this check out by an Hp Tech.
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
