No. They do need to be connected either by wire or wireless to a device to receive data to be printed or through the use of a data card that you can insert in the printer.
Here's a place to start. Go into Control Panel, Programs and Features, and look at each program that starts with "HP". Look up each one on the web and see if they are bloatware, and remove those that are.
If they exist, I uninstall the following... HP Customer Participation Program, Shop for HP Supplies, HP Registration Service, HP Customer Feedback, HP Product Assistant, HP OrderReminder, HP Quick Launch, HP Launch Box, HP Wallpaper, HP Performance Advisor, HP Easy Backup, HP Power Assistant, HP Image Zone Express.
See... http://www.shouldiremoveit.com/HP-oem-bloatware.aspx
There are often many more, but you should research them.
Audria,
Can you be more specific of the Brand and Model of the Wireless Headset you are trying to connect?
Are they wireless via a USB Transmitter or Bluetooth?
Further information helps us help you. :)
when you say the fan runs does it start up and then spin at full speed or just start up spin and stop until needed again.
all thought it may look like your laptop is dead it might just be your screen, if you can see HDD light flashing away then you can assume its the monitor try attaching a external monitor and see what happens
Hi Howard -
A few questions for you - When you press the Power Button, do you see and flashing LEDs? If so, which LEDs and how many times do they flash?
You can try unplugging the system from any power, hold down the power button for 30 seconds (drains all flea power) and plug it in and try. Basic move, but I've had it work several times before.
Let me know -
M
you could take battery out for an hour hope it resets if not you should reflow the mother board If you need further help, I’m available over the phone at https://www.6ya.com/expert/richard_b59056c0c62ecb00
Which operating system ?
Click start control panel on the left select Hardware and Sound
then select manage audio devices then recording you should see a Microphone
right click select enable Windows 7
Click start control panel on the left select hardware and sound
right click select configure speech
recognition then
You will see earphones with a speaker among a list set up a
microphone headset with Microphone then
next and next again you should see your
earphones with microphone being configured
sounds and audio devices select advanced there might be a tick in the mute box
untick it or select audio from the microphone drop down list
Make sure you have the
right one selected and in the volume box make sure the microphone box has a
tick in it or
select the voice tab
Make sure that you have the
right media selected also
select volume make sure the
box for microphone has a tick in it
Windows 7 right click on the speaker icon in the
taskbar select either playback or recording devices you should see your
microphone listed under the recording tab right click on it select
properties at the bottom
select use this device enable
A default email account is the account that your computer will open when you click on an "Email Us" or "Contact Us" link when you are on the Internet. Your computer is pre-programmed to open the Outlook or Windows Mail email servers when you click one of these links. If you prefer to send emails with your Yahoo! Mail account instead, change the default settings. Click the "Start" menu and select "Control Panel." Select "Internet Options" from the "Control Panel" window that opens. Click the "Programs" tab. Click the drop-down menu next to "E-mail." Select "Yahoo! Mail." Click "OK." Yahoo! Mail is now your default mail application. Hope this helps.
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizardif this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorerClose all open programs
Click on Start, Run, and typeregedit and press EnterClick on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose DeleteAfter deleting the keys, close the registry editorReboot your computerOpen My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
if this fails to fix the problemIt could be a problem with the lens you could use a liquid type lens cleaner place 2-3 drops on top of a cd/dvd then run
