Washer will start for a few minutes and then the lights start flashing and the machine cuts off. If it restarts it does the same thing.
SOURCE: code F03
I just had this same problem, it was a bobby pin stuck in the drain motor.... hope this helps
SOURCE: I have a Frigidaire Gallery front load washer with E10 error code
When ours does that it is because of the hard water build up. We have to un-hook the hot water clean out the minerals and it stops doing it.
SOURCE: I have a Frigidaire gallery series front load
E10 = long fill.
Check hoses, faucet and water valve screens first. Clean if necessary. If this did not help - something has failed in the washer, either the pressure switch, control board, or water valve.
Hey friend, thank you for your post!
From my understanding you are receiving an error code of "E90" on your Frigidaire washer. I am showing that as an invalid error code. It might be a miscommunication with your control panel and I would suggest performing a reset on your washer. In order to reset the washer you would need to disconnect the power from it for roughly ten minutes. If you continue to receive an error code of "E90" I would suggest contacting a professional technician for proper diagnosis and repair. Hope this is helpful. -Matt
Thank you for your inquiry, Steve Lesko!
I understand that your Frigidaire washer is displaying an error code of "E62" and the lights on your panel go on and off with a beeping sound. I do not show "E62" as a valid code it could be a possible miscommunication with the control panel and I would recommend performing a reset on your range. You can do that by disconnecting the power from it for roughly ten minutes. Also, think about what may have happened prior to this occurrence. For instance, did you notice any strange functions or other error codes? With this information I can better address the issue at hand. In the meantime, I suggest resetting your washer. If resetting the power does not correct the issue, could you please inform me of the new error code or if your washer continues to display "E62". I look forward to assisting you. -Matt
Hey friend, thank you for the post!
I see from your post that your Frigidaire washer is displaying a PAU code. Normally means the washer has been paused, which could be cleared be pressing either the cancel button or start button once. If that does not clear the code you could try resetting the appliance by disconnecting power. This could be done one of two ways by either unplugging the washer or flipping the household circuit breaker for ten minutes. Please comment back I would like to know if this information has been helpful. -Matt
