Whirlpool Duet GHW9150P Front Load Washer Logo
A
Anonymous Posted on Jun 20, 2014
How much pressure is a whirlpool ft loader washer supposed to have
  • Android Man
    Android Man Jul 01, 2014
    Hi Anonymous, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
    When you ask about pressure, what are you referring to?. Water inlet pressure?
Android Man
Level 2:
Sergeant:
  • Expert 278 Answers
  • Posted on Jul 01, 2014
Android Man
Expert
Level 2:
Sergeant:
Answers
278
Questions
0
Helped
57792
Points
817
2 Related Answers
Anonymous
  • Posted on Jan 09, 2010
SOURCE: whirlpool front loader 6lhw0050pq washer won't
replaced belt
Anonymous
  • 6277 Answers
  • Posted on Jun 19, 2011
SOURCE: low water pressure on whirlpool
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Can I put baking soda in my whirlpool front load washer to wash new sheets?
Hi Ursula B,
You can put baking soda in your washer safely with no harmful effects.
Another good use in your front loader for baking soda.put 1/2 cup of vinegar in your washer soap dispenser,and 2 or 3 tablespoons of baking soda in the fabric softner dispenser and run a hot wash to clean and refresh your washer.
Clothes have lint on them when the washing cycle is finished is there a lint area i need to clean
The newer Whirlpool top-loaders have lint screens on the inner tub and not accessible. These are supposed to self-clean during the drain cycle. I've heard that liquid fabric softener and detergent build-up may clog the screens when lint sticks to the gooey screens. Try something that will cut the goo like vinegar or ammonia in a small load level without clothes. Without clothes in the washer, that is.
Older Whirlpool washers have lint filters located above the tub, on the lid opening.
Good luck from Detroit, MI.
1helpful
I have an f33 error code on the whirlpool duet front loader please help me to fix this.
F33 = PUMP DRIVE SYSTEM ERROR
When the connection between pump and the Central Control Unit (CCU) is lost.
1. Unplug washer or disconnect power.
2. Check wire harness connections to the pump and Central Control Unit (CCU).
3. Faulty CCU < call for service >
Suds indication
Hi!
For a top loader, a general rule of thumb is to lay clothes loosely inside the washer until they reach the top of the agitator. For a front loader, fill it until it's full, with minimal compression of the clothes.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Whirlpool WFW8400TB leaking and not spinning
Send it back and get yourself a nice top loader w/o digital settings. The front loaders look good and all but i see so many unhappy post about them I myself will wash in a bucket before accepting on of the front loads free.
1helpful
Trying to figure out Cu. ft. capacity
hi wanda, most top load whirlpool units, they make the sears kenmore models, are around 3.0 cubic feet.
its not that important for a top loader, but when going to a front loader thats how they rate them.
what i would recommend is you buy a unit that will do the laundry that you will need to do for the next 15 years.
what i mean is if you have 2 or more young children, that you will be doing laundry for the next 15 years, then a full size front loader would do you good. size 3.5 c/f or larger, like a whirlpool he4 or he5.
if it is just for 2 people then a smaller unit would be better, like a whirlpool duet or sport model.
the reason for the choice is a front loader needs to be filled up for it to work properly. doing smaller loads in a front loader will cause them to shake and not work as well.
now be ready as the new washers will cost about 1,000 bucks.
another suggestion for 2 people would be the whirlpool cabrio top loader. i like them alot and they have very few parts to fail and have a good reliability.
good luck and happy shopping.
p.s. remember sears will match prices and give you 10% off the best price!!
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
