20 Most Recent Whirlpool Duet 4.0 Cu. Ft. Steam Washer Questions & Answers
Most duvets can be washed in the washing machine without any problems. If you are just looking to "freshen up" the duvet, you can use the steam/refresh option on your washer for 15-20 minutes. If you'd like to wash it, place it in the washer with similar items (other sheets, pillow cases, etc) and follow the wash instructions on the manufacturer's label. Most can be washed with the normal cycle (cold water).
Whirlpool Duet... | Answered on Mar 12, 2018
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Whirlpool Duet... | Answered on Jul 10, 2015
This will not be necessary if the machine is transported on its back lay it down carefully on its back should not be a problem
Whirlpool Duet... | Answered on Jan 02, 2015
Try removing the panel at the bottom and removing the sump dial by turning it counter-clockwise with a pair of channnel locks. Remove the sump tray and clean out, then reinstall and test.
Whirlpool Duet... | Answered on Nov 23, 2014
I believe you can accomplish this buy going in from back of machine. Be careful of sharp edges, and unplug power. Remove rear panel screws top, bottom, side and side ,you may need to remove hoses. When your in, the pump is at front, and sits on rubber mounts that slide into their metal housings. You will need to disconnect hoses on each side and push the pump forward or backward you will see this when your in there. Remove pump, unscrew filter, check inside impeller area, and check both hoses each way. You would be surprised what kind of stuff gets through. GOOD LUK FRIEND.
Whirlpool Duet... | Answered on Nov 18, 2014
Hi Ursula B,
You can put baking soda in your washer safely with no harmful effects.
Another good use in your front loader for baking soda.put 1/2 cup of vinegar in your washer soap dispenser,and 2 or 3 tablespoons of baking soda in the fabric softner dispenser and run a hot wash to clean and refresh your washer.
Whirlpool Duet... | Answered on May 12, 2014
don't panic/ suds is just what is you have / look in the window. do you see suds/ ok if door is unlocked poor into tub two lids of fabric softner . mixed with a quart of water . wait over night . and everything will be ok . f35 ?? it will probably go away also . if it does not get back with me. . no to stop this from happing again cut down the amount of dergt. or change to the proper type like H E .. hope this helps / ps remove the front panel 3 screws and on the left side remove the drain clean out .. this will help a great deal ..mm feed back please ..mm
Whirlpool Duet... | Answered on Nov 22, 2013
Hello & Welcome to FixYa
F35 error means that there is some sort of issue with the steamer electronic board and analog pressure sensor has gone bad. Check that the hose is firmly attached with the washer and is not blocked. You can also check the water level pressure switch operation. Please get back to me if you have any other questions.
Kevin
Whirlpool Duet... | Answered on Sep 13, 2013
There is no output from the control panel to switch on the inlet valve, so check the inlet valve at this time of the cycle. Also check the water level pressure sensor switch.
Choose another program to confirm if not the controller seems to be suspect.
Whirlpool Duet... | Answered on Jan 26, 2013
Whirlpool Duet 4.0 Cu. Ft. Steam Washer Logo
110 questions posted
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
View Most Popular
duet Whirlpool
  • duet Whirlpool
Most Popular Question
f35 error in diagnostic test c 00
  • Washing Machines
