Missing rear axle. is there a way to replace? the company won't.
I had the same problem. I bought this scooter for my daughter at a flea market and the rear axle was gone, someone had tried to fix it with a bolt, but it was very unstable. Here is what I did and it has seemed to work well. This will cost you less that 10.00 at your nearest home improvement store.
You will need
1x - 5/16 x 8 hex bolt
1x - 5/16 nut
4x - 5/16 x 1 1/4 flat washers
2x - 1 1/4 hard rubber stoppers
1x - 3/8 drill bit & drill
1x - gorilla glue or lock tight
Ok... before we start let me tell you what all this is for and how it works. The way I assembled this was, hex bolt, 1 washer, wheel for scooter, 1 washer, 1 rubber stopper (Insert this into the metal tube on the back of the scooter, so that on the other side you will just have a bolt sticking thru) now, 1x rubber stopper, 1x washer, other scooter wheel, 1x washer, hex nut.
The rubber stoppers are the hardest part and the reason for them is to keep the bolt going thru the middle of the axle tube. This will help to eliminate the scooter from wobbling.
Now, if you have read this far here is how we did it in order.
1. Take both rubber stoppers and trim them with a kitchen knife so that they will fit into the metal tube on the back of the scooter securely. (do not push them all the way in yet)
2. Drill a hole thru the middle of both trimmed rubber stoppers with the drill and bit
3. Take your hex bolt and slide a washer on
4. Slide your 1st wheel on
5. Slide on a 2nd washer
6. push on the trimmed rubber stopper to where it meets the washer. (The wheel should be able to still spin pretty freely, If you think it is to tight just pull the rubber stopper up a bit)
7. Take this assembly and push it into one side of the metal tube on the back of the scooter (you want the rubber stopper to be and flush with the edge of the metal tube and you can)
8. Your hex bolt will be stick out of the other end of the tube, slide on the last rubber stopper try and work it into the tube as best you can.
9. slide on 3rd washer
10. Slide on last wheel
*At this point I put the scooter on its side and pushed down on the wheel to force the stopper into the tube
11. slide on 4th washer
12. screw on nut
*Now I found that if you put the nut on to tight the wheels would not turn, but if you left it loose it would fall off.
13. To fix the above issue we put some gorilla glue on the bolt threads and screwed the nut on, we would spin the back wheels until we were happy with the amount of tension on the wheel. We then put some more glue on the top of the nut to help hold it in place.
14. Let the glue dry
Thats how I fixed my daughters scooter. I am in NO WAY a professional or expert at this stuff. Just a dad trying to make his baby happy. Hope this works for you!
