20 Most Recent
Electric Mobility Invacare Pronto M41 Electric Scooter Power Wheelchair Questions & Answers
What does 3 blinking wrench lights mean?
It is indicating a left motor fault, which is not good news. This is usually from a motor overheating and burning out, usually from overloading the chair or from driving it on unstable terrain like mud, snow, wet grass or sand. If that is the case, there could be more damage to the electronics once you get the motor replaced too. Replacing the motor is a lot of work and very expensive, so you may want to try to find a replacement chair.
10/18/2022 4:31:18 PM •
Electric...
Answered
on Oct 18, 2022
A wrench light is on
When you turn the chair on and move the jostick the wrench light will flash you need to count the number of times it flashes to determine whats wrong ie 4 flashes pause 4 flashes pause. If its 4 flashes then you have a motor problem see my tips on flash codes to determine the problem. Whatever the problem is you will have to have the chair fixed by a tech or the provider that sold you your chair Hope this helps
10/18/2022 4:23:04 PM •
Electric...
Answered
on Oct 18, 2022
How wide is a pegasus4m-g
Standard interior doors are 28" while exterior doors are generally 36" wide. It is paramount to consider that a mobility scooter that is compatible with this size considering is most of the best mobility scooters are 27" wide, which makes for a tight fit unless you have plan it appropriately.
Width Between Arms 20" - 22.5"
7/26/2020 2:15:29 AM •
Electric...
Answered
on Jul 26, 2020
No power new batteries
Yes the control board is likely the cause if all battery connections are checked and pass
9/12/2018 9:28:14 AM •
Electric...
Answered
on Sep 12, 2018
My pronto m41 was not
Hi I would invest in some new batteries ...if they have been in the chair for 3 years without charging them they r no good :::::: when batteries sit 4 a long period a coating forms on. The cells .when this happens they will never charge properly again ..cheers
3/3/2018 4:46:27 AM •
Electric...
Answered
on Mar 03, 2018
Joystick controller
Looks like the other experts are missing the point. The JS is locked out. I would take a pencil put some alum. Foil over the eraser and tap it in the button hole. Turn on the JS and tap the horn twice within 10 sec. This should reset the lockout. do not leave the pencil in the hole!
Strege Mobility I’m happy to assist further over the phone at
https://www.6ya.com/expert/bill_bcbb89783b08c489
6/16/2017 5:32:50 PM •
Electric...
Answered
on Jun 16, 2017
Rascal scooter 245
Most of these chairs have a clutch release lever near the motors. Move it into free-wheeling and it should roll nicely.
3/3/2017 9:56:17 PM •
Electric...
Answered
on Mar 03, 2017
Chair is slowing down. Batteries are fully
How old are the batteries? Even fully charged older batteries can be weaker and not give you as much power to keep the speed at what you are used to. Now a dragging bake can cause you to go slower and also drag the batteries down quicker. Try driving the chair and after awhile check each motor to see if they feel overly warm or hot If one or both feel very warm or hot then I would have the brake or brakes checked If they seen ok I would get the batteries replaced
9/18/2016 3:36:00 PM •
Electric...
Answered
on Sep 18, 2016
