20 Most Recent
Electric Mobility Pride Electric Scooter Throttle Pot Potientiometer Questions & Answers
Tiller column is abit loose/floppy can i adjust or
sounds like the bolt has come loose, follow the tiller and at the pivot point look for a large nut around the bar or a smaller nut/s to the side tighten them and you should be sorted. you may well need to remove some of the panelling to get to it. but it is not hard.
12/12/2013 11:19:19 PM •
Electric...
Answered
on Dec 12, 2013
Hey guys,
I turned the
sufi you will need to replace the speed control pot. Contact Pride @1-800-800-8586 ask for scooter tech support and explain your problem and ask about ordering a new pot hope this helps
1/24/2011 3:52:49 AM •
Electric...
Answered
on Jan 24, 2011
Hello i have a kymco xl mobility scooter which has
Hi , is it the Midi or Maxi XL model ? PG Controller (normally a silver colour ) has the following as the listed fault There is a bad connection to the motor and the controllerIf 's it a Rhino controller normally a blue colour , The battery is completely empty. The scooter does not drive.• Recharge the battery immediately.If the scooter is left off for a few minutes, the battery may recover enoughto allow driving again for a short time. However, driving on an emptybattery may cause damage to the battery.Regardswww.gewizrepairs.co.uk
3/24/2022 8:52:42 AM •
Electric...
Answered
on Mar 24, 2022
Wigwag Throttle Control Pot FREERIDER loose
The spring that applies tension on the wigwag often breaks. After removing the shroud to gain access to the throttle, back off the two allen screws (2mm) and pull off the throttle handles, remove the nut in order to replace the spring. The cost of the spring is about $4.00 compared to the complete throttle at about $250.00.
3/25/2019 7:44:39 AM •
Electric...
Answered
on Mar 25, 2019
