Ice bin fills with water, then freezes.
At first I wanted to say it has to fill with water to make ice but I know you mean the ice bin is filling with water. You either have an issue with the water control valve leaking or your timer isn't working properly. Listen for the water to flow and when it seems to shut off look at the tray fill spout and see if it actually stopped dripping. If it continues to drip (not flow normally) then the valve is leaking. If it isn't dripping but the water in the ice tray over flowed, then the issue is either with the timer or the adjustment is incorrect.
SOURCE: Ice maker will not harvest
As crazy as this sounds, turn the temp control a little warmer (counter clockwise). On this model, this control needs to switch to harvest the ice. A warmer setting should fix this issue.
Dean
You can also go to:
www.u-lineservice.com
SOURCE: My under counter Uline refrigerator/ice maker suddenly trips GFI
I here this alot. If you have a compressor on a gfi the compressor after awhile would trip it. The compressor start amps is usually higher than the gfi is rated. So you have 2 choices. Replace the GFI and try to find one with higher amp ratings. Or install a normal outlet for your unit. Your code will usually call for a gfi, If it does then replace with a new gfi.
To explain the start amps on a compressor depending on your model could be 10 amps. This is for a split second. However the gfi can become week after time. You can also try to plug the unit into a normal outlet to make sure everything is good on the unit. I believe it is the gfi
SOURCE: ice maker shooting water along wall of freezer
Hi...
You need to check this
Regards
PCmania
SOURCE: The bin arm on my Uline Model 402 ice maker broke
1st remove the icemaker from the unit. Then take the faceplate off.You might find that the support housing is fighting you.You should be able to move the arm into place as long as the icemaker is out.
SOURCE: I have a Uline CLR 2160 ice maker. I am trying to
Your display will only show ice or off. There is no temperature settings.Now when I give the directions to put it into clean make sure the green led above the symbols is on steady. If you hold down the on/off key and hit the light key 3 times then release the on/off key last.(give a 1/2 second delay from releasing on/off key. It should go to CL. If led lights dont comeon then let me know.
Check to see if the ice maker is filling with water.
If no then fill with water from the faucet and allow the water to freeze. If
after the water freezes the ice empties into the ice bin and the ice maker
again does not fill with water the=> W10408179
Dual Water Inlet Valve is the problem and will need to be replaced.
If the ice maker does nothing and has ice inside then the=> 4317943 Ice Maker Assembly will need replaced. Thank You Sea
Breeze
Click Here=> 4389177 Water Inlet Valve will need replaced. You mentioned the water is filling the tray OK then my focus would be on the ice maker.
Click Here=> W10190965 Ice Maker Assembly
Most times it is less expensive to just replace the ice maker module. Here is a helpful video that helps explain everything about the Whirlpool Ice Maker below. If you find this solution helpful please rate my solution, Thanks Sea Breeze
