During a cycle, we heard a bang. Everything was clean, but there was water standing in the bottom of the machine. Now there are no lights on, and it won't do anything at all. Any tips?
SOURCE: dishwasher will not drain water out
if plumbed in under the sink, check the spigot the drain hose goes to is not blocked - a common problem. if on drain you should be able to hear the drain pump working. if you hear a faint humming noise instead, then there is probably a foreign object stuck in pump. also check for blockage in the drain hose
SOURCE: DISHWASHER IS LEAKING A LOT OF WATER
Draing Problems:
To fix your draining problem you need to check the air gap(if you have one) , check if there is voltage going to your drain pump during the draining cycle. If there is voltage coming to your water pump and the dishwasher is still not draining then the problem could be a clogged drain hose, a clogged air gap or a bad drain pump. if there is no voltage detedcted on the drain pump during the drain cycle, then it could be a water level-switch/solonioed , wiring, or a control board problem.
Good luck.
Mr Engineer
SOURCE: Flashing lights on Hotpoint FDW20P Dishwasher
No solution! tried resetting to factory defaults but ended up that even the drain pump stopped working. after flooding the kitchen (nearly). I decided it was terminal and am loking for a new dishwasher urgently as I type. Cheers.
SOURCE: Dishwasher doesn't drain
The drain motor might be worn so it still pumps out fairly well but will let wtare back in once it stops pumping. It may also have something stuck in it so it ot is worth removing and cleaning through with a good degreasing cleaner.
