20 Most Recent Whirlpool 24 in. DU920PW Built-In Dishwasher Questions & Answers
Clean the strainer screen on the bottom of the unit.
Whirlpool 24 in.... | Answered on Jan 23, 2018
Make sure your brass line or braided line is hooked up with no kinks or pinches, Then make sure water to valve is turned on.
Whirlpool 24 in.... | Answered on Sep 05, 2012
Yes! Check out this site: www.applianceart.com
They have real stainless replacement panels --- great prices too.
You can even call them with any questions you may have.
Whirlpool 24 in.... | Answered on Aug 24, 2011
can you hear the pump start up..?............
if not,.....pump blocked or duff.............
cheers
Whirlpool 24 in.... | Answered on Mar 27, 2011
Hi!!
Click on the following link to download an owners manual for your Dishwasher. http://www.managemylife.com/mmh/lis_pdf/OWNM/L0906286.pdf everything is set up for you, you can save it to your PC or you can print a copy, just rigt click on the manual and select the option.
Good Night!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Whirlpool 24 in.... | Answered on Dec 10, 2010
Here is a tip that will help you to find out why water will not come into thedishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Whirlpool 24 in.... | Answered on Oct 16, 2010
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Water will not drain out
heatman101
Whirlpool 24 in.... | Answered on Sep 16, 2010
Hi
Thanks for using FixYa. If the dishwasher is overfilling it’s caused because of water-inlet valve going bad. This valve is usually at the bottom left or right of the dishwasher, behind the lower access panel. It's the device with the main water line from the house, a rubber tube to the dishwasher, and two wires attached to it. If the water-inlet valve is defective, you need to completely replace it. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Whirlpool 24 in.... | Answered on Jun 26, 2010
Check water flow into the machine. check strainer attached to the machine. Clean if clogged.
Whirlpool 24 in.... | Answered on May 19, 2010
What temp is your water? You may need to set your water heater up a notch. Try running the dishwasher on the "sani rinse" since this heats to 160 and see if they are drier. Is your heating element working? During the dry cycle with the heat dry on I would open the door and put my hand next to the element to see if it seemed hot. Maybe it isn't working. Also did you put Jet Dry in the dispenser?and also if the setting is adjustable you can dial it up a notch or two. I also like the Jet Dry Turbo. It makes my dishes dry completly, even plastics and this is on the no heat dry.
If there is no heat, then the heating element may be bad. You can get the part, and view diagram at partselect website.
Whirlpool 24 in.... | Answered on May 18, 2010
Looks like micro controller problem. Contact service center for help.
It could be the air gap. If you have one it is mounted on the sink next to the faucet. It is a cylinder about 3 inches high and about 1 inch in diameter (size of a small cup). It is usually stainless steel or chrome in color. You can pull the cap off of the air gap and carefully take the pieces out and clean any debris.
If this does not help the draining then you may have a restriction in the hose from the air gap to the drain, or the dishwasher to the air gap. You can look under the sink and follow the hoses.
Whirlpool 24 in.... | Answered on May 01, 2010
This does sound like a problem with the "anti-flood" device that does detect water (leak / spill) at the base of the washer. This device is a protection device that consists of a polystirene float and a micro swithch. Once a water leak od spill is detected it automatically puts the washer in pump out mode. You need to determine if a leak exists that has caused the float to trigger the micro switch and clear the water / leak. This should put the washer back to normal.
Whirlpool 24 in.... | Answered on Apr 13, 2010
Hi, i have had my new dishwasher for less than 3 hours and is doing the same thing. Not happy Jan!!!! I have dishes everywhere, stuff out of the sink cupboard and a open house in 2 days. Watch out retravision in the morning!!!!!!! Did you get a solution to yours??
Whirlpool 24 in.... | Answered on Mar 25, 2010
The door panels are reversible. Slide it out and turn the panels around. Bingo! Your done. It's that easy.
Whirlpool 24 in.... | Answered on Dec 18, 2009
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter.
Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Whirlpool 24 in.... | Answered on Dec 11, 2009
Whirlpool 24 in. DU920PW Built-In Dishwasher Logo
61 questions posted
Top Whirlpool Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Bruce Denton
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
  • Whirlpool Dishwashers
Most Popular Question
whirlpool dishwasher
  • Dishwashers
