20 Most Recent Hotpoint 24 in. HDA3400G Built-in Dishwasher Questions & Answers
Thankyou Loopyloolisa! you just helped me fix my unresponsive midea dishwasher! Great help
Hotpoint 24 in.... | Answered on Jul 14, 2015
The motor/pump has froze/stuck. Turn off the power and remove the lower front cover which is usually held in place with 4 screws. Underneath in the center is the motor/pump assembly. If you feel around you will come across the motor cool fan. Work it back and forth a few times and it should run.
Hotpoint 24 in.... | Answered on Jul 20, 2014
view the clip it may help you
Hotpoint 24 in.... | Answered on Apr 07, 2012
Same problem here. It's been a while since we used it. HDA 3440GO2SA. I think I've narrowed it down to the motor seizing. I get 12.2 ohms on the windings and a local tech says the windings are good then. Some decent troubleshooting videos here http://www.appliancehelponline.com/dishwashernotrunning.html. Turn the breaker off for the unit (so you have no power), remove the bottom panel and kick plate. take a screw driver and try to turn the motor fan blades. If it turns really hard keep turning it until it loosens up. If it turns freely, pull the plug, test the power coming in with your multimeter (requires turning breaker back on, of course, but after the leads are inserted in the plug). You should have around 120 volts with the door switch activated and wash cycle on. Anyhooo...I plan on trying to pull the hub and clean it up, put some di-electric grease on it and re-assemble. If that doesn't work then I'll debate whether to spend 150+ on a new motor or just get a new dishwasher...lol.
Hotpoint 24 in.... | Answered on Sep 06, 2011
their will some water that always remains in the pump below the fliters is should never be visible in the tub once cycle is over but it must always be there to keep the seals moist to prevent them from dry rotting
Hotpoint 24 in.... | Answered on Aug 26, 2011
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Hotpoint 24 in.... | Answered on Aug 08, 2011
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Hotpoint 24 in.... | Answered on Aug 06, 2011
The motor is stuck. If you remove the lower cover and see a square aluminum motor it is less than 7 years old. Make sure power is off at breaker and rotate the motor shaft
by turning the fins inside the motor.
If the motor is black and round you have to turn
the fan blade which is located in a slot between the metal pump and the plastic
pump. Also once freed, a light shot of silicone or WD-40 (silicone works better) at the
bearing ends. Also check pump for leaks around the drain solenoid (shiny shaft attached
to a plastic triangle). If it's leaking during pumpout, the seal has failed. The pump runs
around 100 dollars typically. Hope this helps.
Hotpoint 24 in.... | Answered on May 30, 2011
have u checked your hoses and water lines,problem might not be machine..
Hotpoint 24 in.... | Answered on Apr 09, 2011
Your heater is not working. Could be a thermostat, the element or even the timer or control board. Call for sevice.
Hotpoint 24 in.... | Answered on Mar 24, 2011
Where does the little plasticWhite ball Ball go Part 454
Hotpoint 24 in.... | Answered on Mar 03, 2011
Hotpoint 24 in. HDA3400G Built-in Dishwasher Logo
118 questions posted
Top Hotpoint Dishwashers Experts
Archie Ferrarini
Archie Ferrarini
Marvin
Marvin
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
  • Hotpoint Dishwashers
Most Popular Question
drain not clogged or blocked line
  • Dishwashers
