I erased all recordings, but when set to the .wav setting, the remain record time is extremely low (8 min). Any idea on fix?
SOURCE: can't connect the h4 handy recorder to a mac
If you are using a Mac running Leopard (Sys 10.5), you need to upgrade the H4 firmware from Zoom website
http://www.zoom.co.jp/english/download/software/h4.php
You will need an external SD card reader.
Good Luck
SOURCE: My zoom multitrack says "check disk"
http://www.zoom.co.jp/archive/English_Manual/E_MRS1044v2.pdf If this is the model you have you have to format the hard disk before using it the first time. You may also have to restore the machine to factory settings using the recovery disk that came with it. The link is to the download for the manual.
SOURCE: my Fostex mr8 hdd "full"
If you can reformat the drive after dumping out anything you want saved MIGHT fix the problem...
The unit MAY not be able to tolerate fragmenting when you delete a snippet here and there... It may require large blocks of contiguous space.
Testimonial: "thanks mate, that was it"
SOURCE: Just got my new Zoom H4n handy recorder and now
It may not be a problem. See if you can perform a facrory reset and start again.
SOURCE: R16 Zoom .... first issue.....
Hi,You will need to do a troubleshooting (general) to be sure where the problem is from..
Have you updated it lately?
If not,
http://www.halerecordings.com/index.php?option=com_jdownloads&Itemid=8&task=view.download&catid=45&cid=5606
get back to me when your through..
Take care..
