20 Most Recent
Zoom H4 Handy Recorder Questions & Answers
H4n menu button doesn't work
If the menu button on your Zoom H4n recorder is not selecting or responding when pressed, it could be due to a few different reasons:
- The button is physically damaged or stuck: Check the button to make sure it is not stuck or physically damaged. Sometimes dirt or debris can accumulate around the button and prevent it from working properly.
- The firmware needs to be updated: If the Zoom H4n recorder has not been updated recently, it's possible that the firmware needs to be updated. This can be done by connecting the recorder to a computer and downloading the latest firmware from the Zoom website.
- The recorder needs to be reset: If the menu button is still not responding, you can try resetting the recorder to its factory settings. This can be done by holding down the "Menu" button and the "Track" button at the same time until the message "Init All" appears on the screen. Then, press the "Record" button to confirm the reset.
If none of these solutions work, it's possible that there is a hardware issue with the recorder and it may need to be repaired or replaced.
The green screen has no lettering on it, the Zoom H4 powers up and screen lights but no lettering is seen
If the green screen on your Zoom H4 recorder is not displaying any lettering, it could be due to a few different issues. Here are some troubleshooting steps you can try:
- Make sure the contrast setting on the device is adjusted properly. If the contrast is too low, it could cause the lettering to be difficult to see. Try adjusting the contrast using the device settings.
- Check the battery level. If the battery is low, it could cause the device to function improperly, including the screen not displaying properly. Try charging or replacing the battery.
- Reset the device to its factory settings. This will erase any custom settings and configurations you may have set up, but it can sometimes help to resolve any software issues. To do this, hold down the "+" and "-" buttons at the same time while turning the device on.
- If none of the above solutions work, there may be a hardware issue with the device's screen or internal components. In this case, it's best to contact Zoom support or bring the device to a repair professional.
When i power my zoom on it powers up but immediatly says goodbye
This issue could indicate a problem with the firmware on the Zoom device. Here are a few things you can try to resolve the problem:
- Update the firmware: Make sure that the firmware on the Zoom device is up to date. You can check for firmware updates on the Zoom website or through the device's settings menu.
- Factory reset: Try performing a factory reset on the device. This can usually be done by holding down a specific button combination while powering on the device. Refer to the device's user manual for specific instructions.
- Check the battery: Make sure the battery level is sufficient and if not, charge the device.
- Check the SD card: If your device uses an SD card, make sure it is properly inserted and formatted. Also, check if there is a problem with the SD card by trying to format it or using a different SD card to see if the problem persists.
- Check for hardware issue: If none of the above steps resolve the issue, it may be a hardware issue. Contact the manufacturer for further assistance or to have the device repaired or replaced.
Zoom handy recorder H4n ver1.72 stuck on ZOOM window
If your Zoom Handy Recorder H4n is stuck on the ZOOM window and you are unable to access the menu or use the recorder, there are a few things you can try to fix the issue:
- Try restarting the recorder by turning it off and then back on again. This can often resolve software issues.
- Check the battery level and make sure that the recorder has enough power to function properly. If the battery is low, charge it or replace it with a new one.
- Try a hard reset by removing the batteries and/or the SD card, then press and hold the power button for 10 seconds before reinserting the batteries and/or SD card.
- If the above steps do not work, try updating the firmware of the recorder. You can download the latest firmware from the Zoom website and follow the instructions for updating the firmware on your device.
- If none of the above steps work, you may need to contact Zoom's customer support for further assistance. They may be able to provide additional troubleshooting steps or repair options.
It's important to note that if the recorder is still under warranty, you should contact Zoom for repair or replacement.
Zoom H4 does not power up on battery power.
Probably two years too late, but I recently got a used H4 and it was having this same issue. Upon reading the documentation, it seemed as though it required a specific type of AA batteries. If you update the firmware (mine was 1.3) to the latest version (currently 2.4), you can toggle the battery type under the menu (most likely alkaline is what you want). It also added lots of other great features!
Zoom H4 recorded data disappearing
I have a H4 but not that problem. Have you tried recording when the H4 is charged? My guess is when low on battery, the H4 doesn't record.
My Zoom H4 Handy Recorder will not power on?
The H4 has a problem with the inside back circuit board disconnecting from the main board. For that you have to take it apart.
Pretty easy for anyone technically inclined. If I remember, 4 screws.
Carefully, of course. Inside you will find the back board (where the power and audio inputs are) unplugged from the main board.
Plug back in, and put some kind of piece of rubber or even cardboard (I did that) retainer to put pressure on and avoid this happening again.
It is a design problem, I had to find out myself.
Hope this helps, please let me know...
Enjoy !
What would cause my Zoom HN4 not to power up from batteries or mains adapter?
You will probably find the bottom board (the one where the inputs go) unplugged from the Main board.
Clean connectors with alcohol, plug back in, and in my case I put in a toothpick to maintain pressure to the chassis. BINGO ! You might check the other boards too and clean battery connectors. Be Happy and Well....
My Zoom H4 will no longer run with batteries.
Probably the connector where you plug the AC adapter into has a switch contact that disconnects the battery when external adapter is used and it has gotten bent so when the adapter is not plugged in, it no longer makes contact to the battery power. This is pretty common for devices that use both battery and adapters.
How to perform a factory reset on zoom H4
Hello ! Actually what you do is download the latest firmware from the ZOOM page. Find HANDY H4 (you can Google that) and go to the Download tab. Follow all instructions. Be sure to have new batteries or be plugged in to AC while you reset. I've done it on my H4(I have 2) and H4n and it worked fine. Be patient, it takes a while once you start. Good luck !!
