Hitachi UltraVision CineForm 55VG825 55" HDTV Logo
p
patty douglas Posted on May 23, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How can i fix my hitachi ultravision it has green and double vision on top of screen
Mike M
Level 3:
  • Hitachi Master 3,349 Answers
  • Posted on May 23, 2014
 Mike M
Hitachi Master
Level 3:
Answers
3349
Questions
0
Helped
686842
Points
16707
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
I have a Hitachi Ultravision TV. I have a problem with the screen like its shows double images on the screen and it has a blue or green dip from the top of the screen. The Model# 60SX12B and this was made...
its a convergence problem, unless you are experienced technician probably not a good idea to fix yourself. usually a reapair shop will charge avg 250-400 for repair
1helpful
Hitachi UltraVision 50ux23k Picture seperation
The best guess is likely convergence control IC's (2 of them STK392-110) and associated circuit problem.
It's acommon fault which causes the symptom you describe - get an estimate - usually between $200-300.
Hdtv that has double vision
There are two common problems with these sets.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
1helpful
Hitachi ultra vision green and purple double vision picture about
Convergence is out, need convergence board repaired, usually bad stks, 392-110s
My hitachi ultra vision television is giving a double picture
This is a common problem with rear projection TVs. It will require pulling the convergence board out of your set and replacing two large ICs and several 1 watt resistors. It can be fixed no other way.
Double vision two picture
conversion chip is blown do a google search on "replace conversion chip"
1helpful
61 Hitachi Ultra Vision has double image
Replace both of your STKs big black ics If they are STK392-110s upgrade to 180s better ics Electronix has them call 1-800-223-3205
Red and Green double vision
Depending on the age of the unit. You have a convergence problem. This is not uncommon. You can contact a servicer thru this homepage and have them look at it. Convergence issues could be anywhere from 200-350 depending on your area.
DOUBLE VISION AT TOP OF MY SCREEN. DISTORTION.
Good Day, wars;
You may have a poor seated cable connector. Unplug TV from A/C, remove back look for a large black connector. It connects between the Main Digital Module and the Drive PWB. Re-insert both ends several times to make better contact, use contact cleaner if have but not always needed. Good Luck, big IRISH.
you will need to replace both convergence ICs they are STK392-110 you will also need six resistors (2) 2.2 ohm 1watt
(2) 1.5 ohm 1watt, (1) 3.3 ohm 1watt and (1) 1.8 ohm 1watt.
You can get replacemnet ICs and resistors at te following link with free instalation instructions. Here is the link.
http://servicemanuals.vstore.ca/
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
