20 Most Recent Hitachi 53UWX10B 53" Rear Projection Television Questions & Answers
You need to have a set top box.
By law, as of March 1, 2007, almost all televisions should include a built-in tuner (called HDTV, digital, or ATSC tuners) that can receive high-definition programs over the air by simply connecting an antenna. Your HDTV doesn't have such a tuner, you'll need to connect an external tuner (or cable or satellite box) to watch high-definition programming. External over-the-air HDTV tuners currently cost at least $150.
Hitachi 53UWX10B... | Answered on Dec 05, 2016
my hitachi projection tv 53uwx10b screen is black with no sound or picture when the power button is on
Hitachi 53UWX10B... | Answered on Jan 12, 2015
There are several common fixes for this model that you can get from www.tvrepairkits.com
Hitachi 53UWX10B... | Answered on Apr 26, 2013
Hello palmer420,
I have that schematic, actually the 43UDX10B which has the same chassis DP-15 and DP-15E. I'll send it to you.
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Hitachi 53UWX10B... | Answered on Mar 31, 2013
the model is phillips and picture above is Hitachi--the philips is not customer repairable--call around and get a estimate.
Hitachi 53UWX10B... | Answered on Oct 17, 2012
have you checked on these :
Hitachi 53UWX10B... | Answered on Sep 19, 2012
you can unscrew the large back plastic section to make the tv a bit narrower...but be careful as this is the piece the mirror is mounted to on the other side...just make sure you have someone help you do it.
Hitachi 53UWX10B... | Answered on Sep 02, 2012
If the picture is 3d looking in some way----it is a convergence problem; many of these sets have "magic focus" and if it will not correct the problem the two convergence chips need to be replaced---this model should use either STK-392-110 OR -150 CHIPS.
This can be a do it yourself repair if you have some skill and total parts cost on Ebay would be under 25 dollars.
Let me know your skill level here and I will instruct you how to do the fix.
SD TECH
Hitachi 53UWX10B... | Answered on Jun 18, 2012
You need to replace STK ICs they are Big Black ICs will have PN# on them STK392-110s use 150s Mats has them 1-800-628-1118
the problem on your tv is the convergence ic part # stk392-110 , that way the magic focus is not working , normal repair cost is about $200 , but if you have some electronics exp you can chance this part other wise i recomend to hire a tv tech to fix this problem
based on model listed here visit the Hitachi site or Google the model number with "manual" to locate a owner manual for this set.
Hitachi 53UWX10B... | Answered on Jun 12, 2012
On that model the conv IC is usually not the solution. I believe its the blown capacitor problem with is an easy fix. Check the site www.TvRepairKits.com for a repair kit.
Hitachi 53UWX10B... | Answered on Apr 13, 2012
Sounds like the convergence has failed which is a common problem with rear projection TV sets. This video has more details on this and info on how to fix it,
Simple answer for this question:
Magic focus is for Convergence and attempts to adjust at about 16 points on the screen---if it does not help the two convergence chips this set uses need to be replaced---small chance if either chip shorted you may have a bad resistor near them also.
See attached photos of convergence problems --no two look the same but you will now know if your problem.
I have replaced chips in hundreds of these Hitachi sets--about the only real issue the sets have--life span on the chips is 5-7 years.
If you can solder and are moderately handy this can be a do it yourself repair--Parts (see photo of chips) cost will be under 25 dollars and the fix for a first time person about one hour.
Happy to help and assist you if you decide to fix it yourself.
Chips look like these and may have the stk-392-150 number on them, a stronger version of the one seen in the photo
Hitachi 53UWX10B... | Answered on Apr 05, 2012
Hitachi 53UWX10B 53" Rear Projection Television Logo
Popular Tags
307 questions posted
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Hitachi Televison & Video
Most Popular Question
53uwx10b picture
  • Televison & Video
