It has a blockage or the water valve needs to be change or it has trapped air,,,,,,,,,this is how to solve the problem,,,,,,u need to locate the valve at the top of the machine (it has a small transparent hose or black)blow a slight amount of air into the hose or to the tip of the hose twice or thrice and try the machine working condition.......best of luck.
SOURCE: Washer won't stop filling
The mixing valve that is part of the connector where the hose is attached has either failed or is disconnected electrically.
These are simple to replace and not too expensive.
You may have gotten some debris into the valve assembly which is being held open and is a sealed device.
If this is the case, it will probably not be removable since the valve is trying to close and will only open if voltage is applied.
