Polaroid TLA-01911C TV Logo
A
Anonymous Posted on May 21, 2014
LG 47lk520 parental pin screen - Polaroid TLA-01911C TV
What is the problem with my 47 inch lg TV model 47lk520 UK screen is black but sound is fine
The back lights in your tv are not working. Please consult someone qualified to repair your set.
1helpful
LG tv model 47LK520 has audio but no picture screen is grey. what is the problem?
Most likely your input button needs to be on a different input , if you have cable on HDMI #1 and a dvd player on HDMI#2 make shure your input button on your remote is on the right input ...also double check your HDMI cables that they are working because I have had cases where they go bad ! hope this helps Sincerely Glenn
Lg 47lk520 reset
tried first to disconnect the supply connector going to the inverter board for back light just to ensure if their is no shorted component here. and then turn the power on again if the light stay then the inverter board was the cause why won't power on. by the way did you make a voltage checking at the power supply board does it have correct output voltages 5v,12-16v and the 24v.
2answers
Forgot my parental control code and losted manual
  1. On the Nintendo DSi Menu, use the stylus to select the Settings ("wrench") icon.
  2. Select the right arrow twice to reach the third page, then select "Parental Controls."
  3. Select "Yes," to change the parental controls.
  4. You will be prompted for your 4-digit PIN.
    • If you know the PIN, select the empty text box and enter the PIN using the on-screen keyboard, then select "OK" to continue.
    • If you don't know the PIN, select "I forgot," then select the empty text box for the answer to the secret question and enter it using the on-screen keyboard. Select "OK" to continue.
    • If you don't know either the PIN or the secret question, the Parental Controls will need to be reset. Please call 1-800-255-3700 for assistance.
  5. Select "Clear Settings," then select "Yes" to confirm.
My "set parental control pin"
May I get the make and model # of the tv to help you more
3helpful
Dont know the parental control PIN
How to Remove Parental Controls:
Use the information below to remove any Parental Controls that have been put in place.
1helpful
I need a parental control reset code
Hi there
Click the "Wii" button located on the bottom left corner of the screen on the Wii Main menu.
Click the "Wii Settings" button on the System Settings screen. Look for the button with the wrench icon.
Move to the second page of the Wii System Settings screen by clicking the blue arrow.
Click the "Parental Controls" button on the second System Settings screen.
Click "I Forgot" when asked asked to enter your four-digit PIN.
Answer the secret question displayed on the screen. You provided the question when you set up your Wii. Note that the answer to the question is case sensitive.
If you answer correctly, you'll have access to the Parental Control Settings. Reset your PIN on this screen by entering a new PIN number and a new answer to the secret question, then clicking OK.
Click "I Forget" if you can't remember the answer to the question. Nintendo displays a message screen with text telling you to contact Nintendo customer support. At the bottom of the screen is a confirmation number.
Write down the confirmation number so you don't forget it, and leave your Wii turned on with the confirmation number screen displayed.
Call Wii customer support at 800-255-3700. Tell Nintendo customer support your confirmation number. You'll receive a master key code to reset your parental control PIN. Write down the master key code.
Return to your Wii, and click the "Enter Master Key" button. On the Master Key screen, enter the five-digit master key you received from Nintendo customer support, then click "Confirm Master Key." The Wii displays a message stating that "Parental Controls are Now Disabled." Click "OK" for the Wii to return you to page two of the Wii Systems Setting screen.
Click the "Parental Controls" button on the Wii System Settings screen. The Parental Controls screen will now show that you have no parental control settings enabled. Enter a new four-digit PIN number and secret question to reset your PIN, then click "OK."
2answers
Forgot parental controls key
You're going to have to call nintendo to remove the parental controls. They will give you a special code to remove the parental controls.
12helpful
Bought a second hand dsi has a parental lock how do i remove it please
How to Change the Parental Controls:
Follow the directions below to make changes to any existing Parental Controls.
    • If you know the PIN, select the empty text box and enter it using the on-screen keyboard, then select "OK" to continue.
  5. Select "PIN" to change the PIN or "Change Settings" to update the setting you wish to change. Once the changes are made, select "Done" to confirm any changes.
3helpful
I am the forgetful parent and need to reset the
1. Turn on your Wii console and go into the Wii Options Menu
2. Click on Wii Settings and click the right arrow until you see “Parental Controls”
3. Say “Yes” to “Change Parental Controls?”
4. Click on “I forgot” when it asks you to enter your pin
5. It will ask you for your secret question, click on “I forgot” again
6. The screen will read “If you have forgotten both your PIN and secret question, call the consumer service number listed in the Wii Operations Manual and provide the confirmation number below. You will be issued a master key.”
7. Call Nintendo at 1-800-255-3700 and give them the confirmation code listed on the screen. They will give you a new Master key to enter on the next screen.
8. The PIN is now reset/disabled
Top Polaroid Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
