SOURCE: I bought Lenovo Ideapad Y430, after 15 days It
Sounds like a new machine. Take it back for replacement or servicing. You may very well have a hardware problem.
SOURCE: onekey recovry error
when u resize your drive you hidden recovery file has been deleted....
Dont forget to rate plz
SOURCE: I am using lenovo y410 when i repartition c drive
When you repartitioned you basically erased the onekey services as they were in a seperate partition on the c drive. You would need a system restore disc in order to reinstall the service on your computer. Sorry.
SOURCE: My lenovo onekey recovery not working?
Hi All,
I am new to to the community. I recently bought a lenovo G series
machine( G550 model #298595Q preloaded with Windows vista and 320 GB HDD) .
surprisingly The C: drive contained 254 GB of the total available 284 GB and
D: drive had the remaining space. I wanted to inistall linux, I had to partition
the C:drive and no where in the lenovo mannual it is warned against the
resizing C:)
I used a partition software called "paragon" to resize my C: drive. My system
hanged while running the process and after a long wait I had to shutdown my
system and after that my OS was not loading.So I decided to recover my vista
using one key recovery. I tried the back up I stored in D: drive and in DVD and
it is giving an error message that "not enough space in the
system" and in the one key recovery menu the target location of the
one key recovery is showing to D: drive but my preloaded vista was installed in
C: drive and also it is showing the total free space as 298 GB)
Could any one help me to get my vista back.( why the target location of one
key recovery is showing to D:)
or is there any way to increase the D: partition from boot setup). Please
help me.
and also my warranty is valid , since I touched my C: drive( no where
it is warned against that)?
SOURCE: to create a recovery partition in harddisk
Unfortunately the Recovery partition could not be reacreated manually. But you can recover it by using the Y410 Recovery Disc but that means reinstalling everything and youll end up with windows vista again. You can reinstall XP but do not delete the partition that usually has 10-15GB of space because that is the hidden partition for the recovery. You can call 18774536686. If your computer is out of warranty, it would only cost you 59$ for the recovery disc
