20 Most Recent
Lenovo G460 Laptop Computer 06774CU Intel Core i5450m Questions & Answers
Why doesn't it shut down correctly?
Laptop not shutting down properly is usually because of a stalled process as with any regular PC or a power management issue. Usually making sure the OS is updated and downloading or reinstalling the latest "chipset" driver from the manufacturer. Unless for some reason you're stuck in a glitch of "update and then shutdown" and the message is nto displaying properly.
Web cam not detected in lenovo g460
Have you recently changed / Upgraded / re-installed your Operating system? If you have made any changes to your operating system, try reinstalling the drivers, if nothing has changed, and the web cam is suddenly not getting detected - take the lappy to a service center
G560
you probably damaged that spot and unfortunately it cant be fixed you will have to replace th screen
My lenovo G460 laptop doesn't turn on ?
Did you have exhausted the battery power? If so, maybe the laptop can't turn on as soon as you plug in the
ac adapter, as you can try to let the laptop charged for a time and then turn on the laptop to see if every thing is well.
How to use the veriface?
VeriFace is a facial recognition software which can do:
- Windows Login
- Leaving a video message
- Login log review
- File encryption/decryption
To use the veriface,you need to install the software for it.Install the veriface software from the motherboard cd given to you or download it from the below link according to your operating system.
http://consumersupport.lenovo.com/ot/en/driversdownloads/APR_Driver_List.aspx?CategoryID=880973
You can find the
veriface driver under
software tab and download it according to your
OS
Installation:
1.Launch the ¡°VeriFaceIII.20090205.EXE¡±installer to the target hard driver.
2.Reboot the system Or enroll your face and then reboot the system.
My laptop won't charge even it is plugged in.
Hello, I am the technician that will be assisting you today. My name is Norman-Wynne Damstra.Welcome to Fixya, Loue Benison.The solution to your problem lies in one of the following three areas:1.) Your charger is faulty and is therefore not able to pass power to your laptops battery.2.) The charging connector on the laptop has come loose from the contacts. Therefore a bad connection.3.) Your battery is faulty.I think senerio 2 is the most likely, although you will have to test senerio 3 by removing the battery and pluging in your charger and seeing if the laptop powers on.If it does power on then that rules out senerio 1 and 2 leaving a faulty battery.Take care!Norman-Wynne Damstra
My laptop is not charging even it is plugged in.
There are two possibilities here.1) Your charger is faulty or there is a break in the wire.2) Your laptop's battery is dead.How old is the laptop? Is it the same battery that came with the laptop when you bought it? When you use the laptop at home or at work do you normally plug it into AC power with or without the battery in the laptop?
I need install win7 from cd for my new lonovo g560
is this a cd or dvd disk windows 7 is usually on a dvd
you will need to boot from the disk if you have an operating system on your Lenovo
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down using the arrow keys to advanced bios features
press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
hope this helps you
