Hello, My extended wifi is connect with a dlink dap 1320 and my livebox 2zte. Setup is complete and the signal from the Dlink strong. But It is impossible to connect to internet
First connect to the Livebox (without the range extender) to see if you can access the internet. If you can get on the net there open your browser and type http://dlinkap.local in the address line, and set-up the d-link. the most common problem is the password on the router (the livebox).
For instructions for the D-Link go here;
http://www.dlink.com/-/media/Consumer_Products/DAP/DAP%201320/Manual/DAP_1320_Manual_EU.pdf
For instructions for the livebox (translated into english);
http://translate.google.com/translate?hl=en&sl=fr&u=http://assistance.orange.fr/installer-la-livebox-2-zte-4665.php&prev=/search%3Fq%3Dlivebox%2B2zte%26rlz%3D1C1ASUT_enUS567US567%26es_sm%3D93
do you know how to network a 7420 fax ?
SOURCE: Set up epson workforce 600 printer wifi via dlink dir615
Configure the IP address range your wireless printer, (this is done through the printer's menu settings) make sure it matches the IP address range on your wireless network, it maybe 192.168.1.*** then configure the wireless printer with a fixed IP address with the same IP address range but higher address eg. 192.168.1.10 so it does not clash with any other IP addresses.
Next install the printer driver normally.
Then configure the printer Properties.
Click Start - Printers and faxes - right click on the Brother printer - click Properties - Port tab - click Add Port - Standard TCP/IP port -
Port Name eg. 192.168.1.10
Printer name eg Network printer
Click OK
Then do a TEST print if it does not work then the IP address is probably incorrect.
