LG 42PC3D 42 in. Plasma Television Logo
T
TONY SOTO Posted on May 05, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
NO PTCTURE BUT I HAVE SOUND - LG 42PC3D 42 in. Plasma Television
Archie Cruz
Level 3:
  • Master 641 Answers
  • Posted on May 05, 2014
Archie Cruz
Master
Level 3:
Answers
641
Questions
0
Helped
163760
Points
1736
Hi Tony,
You may want to check the "INPUT", "SOURCE" or "TV/VIDEO" on your TV remote control. Once you find that button press it once and you should have input lists on your TV screen. All you have to do is to choose one by one on the list until you get the right input to get the picture back. Hope it helps.
Level 3:
Top Expert:
  • LG Master 76,851 Answers
LG Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15008227
Points
237762
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts.
2helpful
Tv is about 6 years old hd-ila 56g657 have replaced lamp 3 times over that time but the picture started to get darker and darker.the last time i replaced the lamp it did very little good and the ptcture...
you cleaned the reflector glass, then tried to make the manual adjustment of the color to have good convergence. you can do the adjustment in the menu set up. if can not get with adjustment, their might be a problem in the convergence circuit board.a bad convergence ic or resistor.
Ringer is marked as off on my blackberry bold 9700 and i have no sound
Hi,Sound profiles define how your BlackBerry device alerts you of phone calls, messages, reminders, and browser content.
Your device has a Normal sound profile and six other preloaded sound profiles: Loud, Medium, Vibrate Only, Silent, Phone Calls Only, and All Alerts Off.
By default, some of the settings in the preloaded sound profiles are based on the settings in the Normal sound profile. For example, when you change the ring tone in the Normal sound profile, the ring tone in the Loud, Medium, and Phone Calls Only sound profiles is automatically updated. If you do not want specific settings for a preloaded sound profile to update automatically when you change the corresponding setting in the Normal profile, you can manually change the settings in that preloaded sound profile.
You can create custom sound profiles. When you assign a custom ring tone to a contact, the ring tone is always active and does not change when you switch sound profiles unless you switch to the All Alerts Off sound profile. Call and message notifications for your contacts might be audible even if you switch your sound profile to Silent or Vibrate Only.
You can change, rename, and delete most preloaded sound profiles. You cannot delete the Vibrate Only sound profile and you cannot change, rename or delete the All Alerts Off sound profiles. You can change the Normal sound profile, but you cannot rename or delete it because some of the settings in the other preloaded sound profiles are based on the settings in the Normal sound profile.
Sound profiles define how your BlackBerry® device alerts you of phone calls, messages, reminders, and browser content.
Change a sound profile
If you change a setting in a preloaded sound profile that is based on the Normal sound profile, that change will override the corresponding Normal sound profile setting in the preloaded sound profile.
1. On the Home screen, click the Sounds icon.
2. Perform one of the following actions:
* To change the active sound profile, click Set Ring Tones/Alerts.
* To change a custom or preloaded sound profile, click Edit Profiles. Click a profile.
3. Click the application or item that you want to change.
4. Change the notification information.
5. Press the Menu key.
6. Click Save.
7. Press the Menu key.
8. Click Save.
Hope that helped...
9helpful
2answers
Error ID = 0xC00D11BA, Condition ID = 0x00000000
Your sound card might be in use by another application.
0xC00D11BA: Cannot play the file
Windows Media Player cannot play the file because there is a problem with
your sound device, such as a sound card or sound controller. You may
encounter this error message for one of the following reasons:
Your sound device is in use by another program. Quit other programs that may
be using your sound device, and then try to play the file again.
Your sound device is not functioning properly. To troubleshoot the problem,
see the Sound Troubleshooter in Windows Help or refer to your sound device's
documentation.
You do not have a sound device installed on your computer. Install a sound
1helpful
3answers
My sound card is not working
look for the model number on the card and goto the manufactures website and download the driver
3helpful
Sound Quality Comparision
Slight difference.....The sound quality difference is observed.
You can find out the difference.In every motherboard on board sound is not so good.But in sound cards it is disigned specifically for sound.
if it helps
Pls RATE ME
14helpful
5answers
Free sound driver
i need creative sound card driwer
12helpful
10answers
NO SOUND ON MY COMPUTER
i need help put sound on my computer, and where to go to download a sound device driver
Dark picture
require model and make of unit and what code are you requesting .
Ptcture
Sounds to me like you might be in "test"mode. You'll have to find the correct button to press to get you back in the other function. If this fails, you'll need a tech visit...accordianman
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
