20 Most Recent JVC HD-56FB97 HDTV Questions & Answers
0answers
Lamp turns on lamp light starts blinking then turns off
Check the lamp ballast, it works just like a flourecent light if the ballast is bad it will turn the light off. It comes on a board try searchinng ......ebay or thetvdoctor.comXHRWN5
3/4/2015 4:07:36 AM • JVC HD-56FB97... • Answered on Mar 04, 2015
Does a 56 "jvc need to have a video card to use for just regular tv,or is the video card for using a vid cam
This TV should work with a video camera fairly easily.
8/21/2014 3:37:02 PM • JVC HD-56FB97... • Answered on Aug 21, 2014
Tv is about 6 years old hd-ila 56g657 have replaced lamp 3 times over that time but the picture started to get darker and darker.the last time i replaced the lamp it did very little good and the ptctu
you cleaned the reflector glass, then tried to make the manual adjustment of the color to have good convergence. you can do the adjustment in the menu set up. if can not get with adjustment, their might be a problem in the convergence circuit board.a bad convergence ic or resistor.
5/21/2014 7:36:14 PM • JVC HD-56FB97... • Answered on May 21, 2014
How do i replace a bulb on a JVC D-ILA tv?
Good Day,
To get the Lamp part number TS-CL11OUAA, around $200.00 cost, 1-800-252-5722/ www.jvc.com.
To replace: The Lamp will come intructions. It is very easy to replace if you have a phillips screw driver.
Good Luck, big IRISH.
10/26/2012 11:52:53 PM • JVC HD-56FB97... • Answered on Oct 26, 2012
What would make my tv power on click and the power light starts flashing
hi if the tv light is flashing this gives a error code. count how many flashes there are then search on google it may give the possible fault. my guess it could be capacitors hope it helpsregardsshaun
11/20/2011 12:56:11 PM • JVC HD-56FB97... • Answered on Nov 20, 2011
Our JVC AV-56WP30 projection set
Replace STKs in convergence board.
6/7/2011 1:43:23 PM • JVC HD-56FB97... • Answered on Jun 07, 2011
My projection television lamp is broken how can i
If you have gotten the lamp out of the tv and checked it and it has broken glass, then you are half way in getting it fixed. Go to pureglare.com for the best price for the lamp with the housing. They warranty the lamp as well. Of course, when you get to the site you must put in the make and model number so have it handy. When you put the lamp back in you must be sure you plug it all the way in. You will feel it plug in and seat firmly. Also the set will not come on until you put the door of the lamp back on as well.
5/24/2011 9:22:56 AM • JVC HD-56FB97... • Answered on May 24, 2011
2answers
I have a JVC HD-ILA
I only have bad news for you. This tv uses an engine assembly. It is impossible to replace the color wheel only. The entire assembly is quite expensive and wouldn't be worth replacing for a tv of that age. (By expensive, I mean roughly $400-$600, before labor). To replace the assembly the tv is basically broken completely down for this repair too and thus very expensive for labor as well.
Sorry for the bad news, but with no warranty you seem to be out of options. Some people choose to just live with the color issues, while saving for a new tv.
Thank you and have a nice day! :)
Please rate
4/7/2011 12:41:05 PM • JVC HD-56FB97... • Answered on Apr 07, 2011
The picture has a yellow
JUST CHECK THE HUE
2/3/2011 7:29:47 PM • JVC HD-56FB97... • Answered on Feb 03, 2011
I have a 52 inch
seems like the bulb has blown
1/10/2011 1:13:07 AM • JVC HD-56FB97... • Answered on Jan 10, 2011
Blue light flashing and TV not working, then a
OK this will sound strange but I got these instruction for my Toshiba and for some reason it seems to be a common problem for rear project TVs. Unplug the TV, remove the bulb housing from the TV and tap it firmly on a counter top ten times. Then reinstall it, plug it in and turn it on. There is some sensor that is monitoring the bulb when it is heating up.
1/4/2011 6:16:43 PM • JVC HD-56FB97... • Answered on Jan 04, 2011
Both the blue power light
I had a similar problem with my 42 in Philips LCD HDTV.
Here was the problem. My Power Supply Board had several bad capacitors. I opened my TV (warranty was expired of course) and found four bulged capacitors on the PSB. Many major electronics companies Philips/Magnavox, Sony, Panasonic, and others were sold capacitors that failed in 2-5 years instead of 10-20. The capacitors fail prematurely due to a lack of preservatives. Unfortunately, they were installed in all sorts of devices and cause a wide range of failure problems.
Here are some options for you.
1. Have it fixed by a professional $$$$$$$??????? (Is it under warranty?)
Remember, TVs CONTAIN HIGH VOLTAGE AND CAN KILL YOU! Do this at your own risk.
2. Open your TV and find PSB. (The board that the power cord plugs into) Check for faulty caps. If you find some (bulged or leaking) bad caps replace the entire board. The entire board costs around $250 right now because they are in high demand right now. They can be found online. I would definitely shop around though.
3. Remove and then replace individual faulty caps. This takes some soldering skill.
Caps are inexpensive and if you can take care of it yourself it will save you hundreds.
This may be your problem. If you determine that it might be.
I have a Tip/How TO tutorial on this site that may also help. It gives step by step instructions for replacing caps on PSB #715t2432-2. If this is your board you are in luck. Here is the Link: Fixing the Philips Turns/shuts off on its own problem. I
12/20/2010 4:33:49 AM • JVC HD-56FB97... • Answered on Dec 20, 2010
How much does it cost
A new power board for that model TV is $350.95 with free shipping, it can be found here:
http://www.partstore.com/Part/Matsushita/JVC/HD56FB97/Matsushita/JVC/SSD2205AM2R/New.aspx
Please make sure you rate my answer 4 thumbs up, it is extremely important to me. I would be forever grateful if you could do so. If you need more help on this question please just respond to my answer here and I will get right back to you.
Thanks
Tim
10/21/2010 7:32:40 PM • JVC HD-56FB97... • Answered on Oct 21, 2010
I turn on my tv and i just here a noise and the
Most likely it is bad convergence IC's that are causing this. I would recommend having it looked at by a professional. If you are considering doing it yourself you would need considerable solder experience as well as electronic troubleshooting. You can locate the nearest service center here:
http://maps.jvc.com/casclist/index.asp
If you have any other questions let me know.
Thank you,
Lee
5/19/2010 10:57:09 PM • JVC HD-56FB97... • Answered on May 19, 2010
JVC HD-56FB97 HDTV Logo
Popular Tags
44 questions posted
Top JVC Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
 Grubhead
Grubhead
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • JVC Televison & Video
Most Popular Question
tv about 6 years old hd ila 56g657
  • Televison & Video
