There is a white felt like tube on the top of the tank after you remove the top you will see this slide it out and replace the 2 microtemp fuses part number g4a01 at 141c. or 285.8 f use 2 of them just like they are in the unit . if too mutch to handle call bunn if under 3 years they will replace whole thing
With video games this is generally a heat sync problem or a solder break down problem. It is a time consuming job but you can do what is called a reflow of the board, buy some heat paste and re-seat the heat sync and should work. You need to do your research first though because it is an all or nothing on this.
Induction stovetops wont heat until a metal pot is put on top of the element. They work through electromagnetism. These tops wont work with glass or aluminium pots. They have to be steel.
you must op popped the maind fuse. follow the posive baterry cable. somewhere between the end and the fuses that do not have power is a bigger fuse that popped.. Being this old of a truck I have not location information but it should be pretty east to find. Its also possible this uses a fusible link wire.
It sounds like the thermostat is loose and needs to be adjusted or replaced. Leave this to a professional if you don't know what you're doing. So many fires are caused by baseboard heaters.
No heat or no air volume? No heat may mean no coolant! check it now! Your 4.2 wont stand for being overheated. No volume, check the fuse, if ok then turn on you fan and check for voltage at the electrical connector at the blower motor (under the glovebox). If you dont have a test light, tap the blower motor . If that kicks it to life you need a blower motor.
