20 Most Recent
Keurig Ultra B50 1-Cup Coffee Maker Questions & Answers
Ants in my Keurig
I had the same problem after getting a Keurig model 525C and took it back to Costco, with ants still in the coffee maker. I haven't had this problem with other Keurig coffee makers. Keurig needs to come clean and admit THEY have a problem with at least one of their coffee makers.
K cup explodes
This happened to me with a B30. I called and they had me clean everything out thoroughly. at the very end the tech support lady explained the issue is with the kcups themselves. the ones with bulging tops have extra air in them that causes problems when brewing.
Lukewarm coffee
these machines arnt meant to be repaired. contact keurig and if it in the company warrenty period they will replace it. otherwise throw it out. we throw away tons.
Coffee grounds in cup w/ Keurig 60
I have the answer because it is happening to me now. Moreso with the Timmothy's brand K cups. I did a little forensics on a good brew, and then on two slow with grounds in the final brewed coffee.
The inner filter is placed in the k cup and it is not glued to the top rim. The bag then just sits on the bottom of the k cup as it is passed with the hot pressurized water.
The good cups are glued to the top rim and there is no problem.
To investigate....remove the foil top carefully after the cup cools. Rinse out the grounds, and the filter bag should still be glued to the rim. if you've got a dribbler and one that passes the grounds into the cup...you will find the filter bag had fallen loose from the rim. Manufacturer defect...You bet!!!
I had 8 from a box of Timmothys 25 count pass grounds. Green mountain coffee may once in a while pass grounds, but very rare and maybe three times in the 4,000 k-cups we've used.
How to take apart keurig
my coffe maker quit working right also so i called customer service and they walked me through cleaning out the k-cup poker if that does not solve the problem they will walk you all the things you can try or tell you how to exchange it for a working one because they have a great warranty program so don't do anything without checking the manual and calling customer service . so you don't void the warranty . they are very helpful and nice so i would say that is your best option
The unit is completly dead
Good evening to youSo no coffee for you tonightI would try taking the coffee machine to the shop it came from or does sells the same type, and ask what is wrong with the electricity.good luckKolbrun
No water comes out of coffee machine
Hello, minervaI was trying to help you out here. Maybe this will help some? I was going backto some customers that asked questions in the recent past and even fartherback. It appeared that no one answeredsome of them, So, I thought I would take some of my personal time to see if Ican help. Even though this Informational site may not have your exact model orbrand, this site will help you a lot. Here is a site link about everything you want to know about CoffeeMakers and possibly yours, from repair to trouble shooting it. b>
http://home.howstuffworks.com/coffee-maker4.htmPlease if this helped you at all, if you can find the time and in your heart torate my help and some kind words written would be appreciated for my free help, I would appreciate it. Here is also my direct link to my own pages of other areas of my expertise forother problems you might have in Automotive, Appliance, and Electronics. DropIn anytime for my help.Thanks, Mikehttp://beta.fixya.com/users/mc1bean
