SOURCE: BONJOUR MONSIEUR :JAI DES PROBLEMES AVEC MON IMPRIMANTE HP500PS
MY DESIGNJET 500 HAVE THE 79:04 ERROR IT WAS JUST CUTTING THE PAPER WHEN THIS OCURR
SOURCE: Bonsoir, Description du pb : "Echec système
En anglais - c'est trop longtemps que je parle francais...
The code you mentioned sounds like an Ink System Failure code. My C6180 had the 0xc19a0035 Ink System Failure code, eventually the printer would power on and off every 15-20 seconds - continuously. Apparently some defective components were used in the construction of the logic board (see photo). On my C6180 there were 3 failed capacitors (the green cylinders - the puffed top indicates failure) and a 4th from the same manufacturer (TEAPO - many unfavorable web references to this manufacturer). I purchased 3x 330uF 16V and 1x 680uF 10v rated to 105 degrees Celsius (total about 60cents). On the logic board, the capacitors I replaced are labeled C613, C614, C660 and C662. If you are not comfortable replacing the parts yourself (or don't have a soldering tool), you will have to find someone who will. The time to repair should be less than 30 min - I did it in 25 min with only a solder pen. This fixed the on and off problem and also fixed the ink system failures the printer was having. A similar fix may apply to other HP printers.
For 58.4 errors, replace the engine power supply.
