20 Most Recent HP LaserJet M4345 MultiFunction Printer Questions & Answers
It may be your ink you need to renew
HP LaserJet... | Answered on Jan 12, 2019
13.20.00 can be also caused be a jam near the fuser (the part of the printer that gets hot to make the toner stick to the paper). Remove the toner cartridge and take a look for small scraps of paper along the whole path. Also open the door on the back of the printer and look for paper scraps from there. If you see paper stuck in the fuser, do not use anything sharp to remove it, be careful not to scratch the surfaces.
HP LaserJet... | Answered on Jan 10, 2019
  • The printer experienced a low voltage power supply unit malfunction.
  • Remedy:1. Turn the printer off and then back on. NOTE: This error might be caused by source power related issues. Determine if the area where the printer is located has experienced brown outs or is subject to power quality issues. 2. Ensure printer is plug into dedicated power outlet. 3. Reconnect the connector (J102) on the DC controller PCA. 4. If error persists, replace the Low Voltage Power Supply (
HP LaserJet... | Answered on Oct 10, 2018
The tray lifting error is displayed as 60.02 Tray 2 lifting error. To fix this error, check the surface sensor of the paper tray2 in the Manual Sensor Test 2 menu under the Troubleshooting menu.
Connect back the cassette lifter motor and the DC controller PCA's connectors and now, replace the filter driver unit in your printer.
123 hp com Quick HP Printers Setup Easy Installation Guidelines
HP LaserJet... | Answered on Jan 06, 2018
hp laserjet m1132 mfp errer E3
HP LaserJet... | Answered on Nov 27, 2017
Calibrate the control panel
Use the following procedure to calibrate the control panel:
1. Turn the device off.
2. Press and hold the # key and the C key.
3. Turn the device on.
4. When a small white square appears in the upper-left corner of the control-panel display, touch
the square with a stylus.
5. When a small white square appears in the lower-left corner of the control-panel display, touch
6. Allow the device to finish the boot process.
Hope this helps.
HP LaserJet... | Answered on Sep 28, 2016
How to remove the error reattached output bin HP m4345mfp
HP LaserJet... | Answered on Sep 18, 2015
I'm assuming that you're trying to scan to your computer.?? I'm not specifically knowledgeable about the HP M4345 printer.... but, it HAS to have a cable connection. The cable should be one that has a usb connection on one end, and a small kind of rectangular plug on the other that plugs into the back of the printer.. Look on the back of the printer. There has to be a connection, besides the jack for the 110 V.
HP LaserJet... | Answered on Sep 10, 2015
my experience says jamming in duplex area using card stock. this may occur if default is duplexing. set default to single side and / or try same job using plain a4 80gm2
HP LaserJet... | Answered on Aug 05, 2015
Where did you see that code?!!!!
HP LaserJet... | Answered on Feb 18, 2015
Check the tray feed rollers
HP LaserJet... | Answered on Jan 31, 2015
check the feed tyres, customer changeable
HP LaserJet... | Answered on Jan 27, 2015
it might be the problem of cartridge drum is not rotating properly pls change the cartridge or change the main motor assembly
HP LaserJet... | Answered on Nov 28, 2014
switch on the printer
while memory counting press 3 then all led will glow stable then press 9 then start button u will find full nvram on display then press 6
58.04 error is an Engine Power Supply error.
RM1-1041 is the part number for 110v
RM1-1042 is the part number for 220v.
You will need a tech to swap it out. You have to strip the printer down to get to the part.
HP LaserJet... | Answered on Oct 01, 2014
Try initalizing the Harddrive if that doesn't work.
Try replacing the scanner controlboard or the DC controller.
Or if the MFP is in a dusty room try cleaning the lenses and mirrors in the scanner unit first
HP LaserJet... | Answered on Jul 31, 2014
Resetting the HP LaserJet Pro M1536dnf accomplishes the following:
  • Clears all data from the printer's memory (including unprinted data, downloaded fonts, and macros).
  • Stops any printing that is taking place and ejects the page.
  • Removes some error conditions.
  • Resets the printer to its factory default settings.
Reset Procedure:
  • Turn off the printer
  • Press and hold the Left arrow & Cancel while you turn on the printer
  • Once you see Permanent Storage Init you can release the buttons.
  • The printer should now start resetting.
Thanks,
HP Printer Support
HP LaserJet... | Answered on Jun 10, 2014
HP LaserJet M4345 MultiFunction Printer Logo
206 questions posted
Clive
Clive
View Most Popular
LaserJet HP
  • LaserJet HP
Most Popular Question
cold reset hp m1132 mfp printer
  • Office Equipment & Supplies
