20 Most Recent
Palm Treo 750v Smartphone Questions & Answers
How can I configure my GPRS?
Call your service provider's customer care and ask to send GPRS settings and activate GPRS for your card.You would get settings as sms. Just save it and access GPRS.
How do i change IME number ?
Hello
It is impossible to change your IME number because it was provided by the manufacturer.
Each phone has its IME number for security purpose and can never be change.
Regards.
I have a palm treo that isn't booting.
I believe this means your battery is no longer sustaining a charge enough to power your phone. I would recommend replacing the battery. You should be able to buy a new or used battery from your phone vendor or authorized reseller.
Good Luck,
Jesse
Can't hear anything
i had this problem with my tmobile shadow. i had to get a bluetooth earpiece and everything worked fine. if not you may need to get a new phone.
Hi. I've just bought palm treo 750v on the market
Normal
0
The best thing I can do for you is to refer you to the free
palm chat. For the palm phones I have to know what service provider you use to
be able to get you to the correct link. So here is a link to palm support for
your phone. Click on the icon for your service provider (Rodgers, AT & T or
Palm) From there you want to click on the words “downloads” at
the top of the page. From there you will be able to download all the software you need to get your phone up and running. Best wishes…I hope this will help you.
http://kb.palm.com/wps/portal/kb/na/deviceselector/page_en.html#NA%20Phones:Treo%20750
Je n'ai plus de tonalité quand je téléphone, plus de son
Mouais, il manque un peu d'info pour vraiment cibler le probleme mais je vais commencer par y aller avec le plus simple et évident, et si ce n'est pas le problème, récris un commentaire pour préciser pas de son dans quel sens. Donc, tout simplement a priori comme ca, je dirais que le haut-parleur de ton tréo est brisé, ou encore qu'un des connections ou soudures qui le relient a la carte principale du tréo a cédé. Si tu es sur que ce n'est pas ton cas, alors faudrait que tu précises si t'as juste aucune sonnerie mas que tu entends quand meme quelques sons quand par exemple tu fais jouer un MP3 ou quelquechose. Ou encore si vraiment tu n'entends pas parler la personne quand elle décroche mais que tu entends ta sonnerie quand quelqu'un t'appelle. Bref, essaye d'etre le plus précis possible et de me dire tous les modes ou le son fonctionne ou fonctionne pas. Voila, donc en espérant t'avoir un peu aider, sinon j'attends de tes nouvelles pour pouvoir essayer de mieux comprendre le probleme et te trouver une solution.
I want to change language
unfortunately you cannot just switch languages on the treo or really any Windows Mobile Treo or Palm
They release the phones with one language installed in whatever country and thats about it.
You can buy a Treo 750 in english, but not change the language
Change language to english
We send the second List (Cash-Report from 30.04.2008). Beim festen Vorschuss haben wir per 30.04.2008 CHF 200'000.00 zurück bezahlt.
Mit freundlichem Gruss
How to upload songs in the palm treo 750?
if you got external memory card then put the songs in memory card through pc (if you laptop does not have the sd card slot then you need to do it with card reader)
or simply connect treo with pc through usb and upload it
Palm Treo 750v
Have you tried removing the battery then putting it back in?
I cant make a call
You have an earpiece failure. You would need to get the earpiece swapped out by a phone technician or you would need to call your carrier and speak with someone about getting another device through warranty.
